Author Topic: the low Hi  (Read 1305 times)
mjhoffman
the low Hi
« on: July 08, 2005, 09:02:54 PM »
Where did the low hi come from?  You say "Whats the low hi?"  the low hi is the wave that a passing motorcyclist gets around my area(southeastern Washington).  I've also seen it done in Montana by passing motorcyclist.  What happened to "tipping your hat" or "just a nice wave" or a "node of the head".  It maybe a easy slide off your handlebar expression that is safer than picking up your arm and waving, where that could  be mistaken for flicking a bugger or flipping an ash or something. Is it a HD thing?  Is it a Honda thing? Just seems like the low hi is in!  Your thoughts
Mike
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
Re: the low Hi
« Reply #1 on: July 08, 2005, 09:32:05 PM »
You'd look pretty goofy with your hand up in the air waving at someone  :D  It's the equivalent to a nod of the head, but easier to see.  Just drop your left hand off the bars and let aerodynamics take over.
Offline heffay
Re: the low Hi
« Reply #2 on: July 09, 2005, 03:50:48 PM »
precisely why none of my low hi's never look the same.
