Author Topic: Tank Badges - Any tips?  (Read 2526 times)
Offline martini
« on: August 15, 2007, 10:44:24 AM »
I just received new tank badges for my 750k0. I'm going to install them tonight hopefully and I'm just wondering if anyone has any tips for removing the old badges without damaging the paint and installing the new ones. I understand these can sometimes be tricky to remove and install?
Any tips greatly appreciated.
Offline Bob Wessner
  • "Carbs Suck!"
Re: Tank Badges - Any tips?
« Reply #1 on: August 15, 2007, 12:16:53 PM »
My suggestion would be to use some masking tape above and below the old badges and get it snug to the badge. I used a table knife (not that sharp and now point) inserted under the badge. I think the pins are near the "O' and the "D" and pry it off carefully.
When I put my new ones on, they were straight, as in no contour curve, so if yours are the same, you have to pre-shape them a bit. I also used some double sided trim tape from an auto parts place to hold them on. Just inserting the pins from the new badges into the holes probably will not hold.
Offline techy5025
  • 1969 Diecast and Sandcast 750's
« Reply #2 on: August 15, 2007, 12:51:33 PM »
One problem may be the two small inserts that go into the metal piece on the side of the tank to hold the badges in place. In my case they fell apart when I prized out the old badges. As I recall, they are made of a very thin metal that, over the years, rusts and falls apart.
The badges themselves should come out easily if you use two thin flat screwdrivers....one above and one below each end of the badges....swapping ends as they come out in small increments. Prize in line with where the pins are on the back of the badge. As Bob says, use painters tape to protect the paint.
The inserts are still available. I think I got my replacements from the Dutch guys. Four are required for both sides of the tank.
Jim
1969 750 K0 (Reborn)
1969 Sandcast 750 K0 (Reborn)
2003 CBR600F4I
Offline martini
« Reply #3 on: August 15, 2007, 01:25:31 PM »
Thank you gentlemen, much appreciated.
Bob - you used a two way tape, in addition to the pins?
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #4 on: August 15, 2007, 01:27:16 PM »
Yes, paid too much for mine to risk having them fall off.
Offline angeldeville
  • You meet the nicest people on a Honda!
« Reply #5 on: August 15, 2007, 01:48:00 PM »
two pieces of dental floss from either end, and tug each side gently until the come off.
the little metal wigits can be purchased, new for a couple $$ each.
Please don't be one of the PO's that uses double sided tape.... please....
76' cb750f custom
69' cb750 sandcast
69' CT90
Amen Saviour 750 Chopper frame
and enough parts to build about 6-7 more bikes
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #6 on: August 15, 2007, 01:49:14 PM »
Why not?
« Reply #7 on: August 15, 2007, 01:55:10 PM »
Why not?
If the badges need to be removed again you risk bending them, or damaging the tank, trying to get em off.
The tape retains water, water = rust
for $10 or $12, you can purchase new retainers, and the retainers have worked for 30+ years.
76' cb750f custom
69' cb750 sandcast
69' CT90
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #8 on: August 15, 2007, 02:00:40 PM »
Why not?
Good points.
Offline mcpuffett
« Reply #9 on: August 15, 2007, 02:27:29 PM »
I used some bathroom sealant on the back of my tank badges to hold them on  ;), cheers mick.
« Reply #10 on: August 15, 2007, 03:12:50 PM »
If you have some 30lb test fishing line that will cut through most stuff and leave the paint alone. Wrap the line around wood or whatever and use that to pull on rather than cut your fingers. I am sure you already knew that.
Offline oldfordguy
  • A sheepdog.
« Reply #11 on: August 15, 2007, 06:14:30 PM »
I found little metal "push nut" retainers that would work at my local Ace hardware store, for like 30 cents apiece.
Offline martini
« Reply #12 on: August 16, 2007, 07:25:44 AM »
Thanks for all the suggestions - I installed them last night and I must say it was probably the eaiest thing I've had to do on that bike. They pried off super easy, clips remained in place, pushed the new ones on, they shaped to the tank real easy. Bobs you uncle - whole process took 15 minutes. The new badges look real purty too!
