Author Topic: gas cap gasket and flip latch 71 cb 750  (Read 2405 times)
Offline original
« on: August 15, 2007, 11:50:38 AM »
anyone know where to get a new gasket and the thumb latch for a 71 750 tank. the dealer in my area are not at all helpful with any ordering of parts.  thanks
sloanr
Re: gas cap gasket and flip latch 71 cb 750
« Reply #1 on: August 15, 2007, 01:04:48 PM »
Check out www.bikebandit.com. They have a pretty good selection of hard-to-find parts. I too am in need of the latch for my '72 CB750K2, but neither bikebandit.com nor my local Honda shop have it for less than $35. The gasket should run about $5.
Hope this helps.
Offline Kevin D
  • SE Michigan
« Reply #2 on: August 15, 2007, 01:53:51 PM »
Good luck on finding the latch. I think its an obsolete item, replaced under a recall with the keyed latch. Maybe here, in Holland, it says superseded, but maybe available as pictured: 17517-300-340 http://www.cmsnl.com/honda-cb750k1-four-usa_model14354/partslist/F11.html
I found out the hard way this past winter that the 71k1 uses this gasket on the cap:
17525-300-000. Bought a new cap, it came with a thicker gasket, and the cap wouldn't close/latch until I refitted it with the thinner gasket.
Heres another good parts list, in USA, there are several online retailers using it:
http://www.crotchrocket.com/fiche_section_detail.asp
« Last Edit: August 15, 2007, 01:56:41 PM by Kevin D »
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
« Reply #3 on: August 16, 2007, 03:32:04 AM »
The latch s defiately obsoleted ad the only pat available is the locking type  which any key fits and is a 400 four part
Offline GNXFan
« Reply #4 on: August 16, 2007, 04:43:25 AM »
They are available at www.servicehonda.com. That's where I got mine for my K1.
Offline 736cc
« Reply #5 on: August 16, 2007, 05:04:42 AM »
almost every Honda (but not all) from that era have same latch sp browse your local junkyard or ebay
