Author Topic: dyna coil  (Read 1451 times)
Offline bert96
  • past ride
dyna coil
« on: August 16, 2007, 06:17:25 AM »
 How can i check if my dyna coil are good?
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
Offline OldSchool_IsCool
  • Really feeling like an
Re: dyna coil
« Reply #1 on: August 16, 2007, 08:23:51 AM »
If you have them on a bike with a good battery and points/trigger, then pull out a spark plug, ground the plug to the block and kick/start to see if you get a spark.
If it's not on a bike, then I'm not sure of any test procedures to guarantee a working coil.
By the way, welcome to the forum!
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline bert96
  • past ride
Re: dyna coil
« Reply #2 on: August 16, 2007, 08:45:01 AM »
 THANKS!,but they are not on the bike...;(
Offline Bodi
Re: dyna coil
« Reply #3 on: August 16, 2007, 09:03:26 AM »
First measure the thing with a good ohmmeter. It should have close to the rated resistance between the primary (12V) wires - 5 ohm coils should be 4 to 6 ohms.
Then measure between the spark wire posts or wires. This should be a fairly high resistance, I don't have a figure to give you. Then measure from each plug post/wire to the primary wires, this should read infinity or "error" on some digital meters.
You should not power test a coil with no spark gap, it might arc inside and be damaged. If you have wires, just put a plug on each wire and tape the thread/hex parts together so the gaps are opposite and open. Then connect a 12V battery to the primary wires for a short time (a second or less) and then remove the power. The coil should spark the plugs when the power is removed. Don't hold any primary wire conductor directly or you'll get a good shock - the coil produces a fairly high voltage across the primary when the secondary sparks - only hold the insulation on the wires.
Offline bert96
  • past ride
Re: dyna coil
« Reply #4 on: August 16, 2007, 09:36:56 AM »
 Thanks a lot!
