Author Topic: any gas tank sealer sold in stores  (Read 9393 times)
Offline cb650 bobber
  • Expert I ain't no stinken
  • stupid gloripope
« on: August 16, 2007, 07:04:55 AM »
I need a gas tank sealer pronto do they sell any brands of gas tank sealer that are good in stores.
"I make a point of staying right at the edge of poverty. I don't have a pair of pants without a hole in them, and the only pair of boots I have are on my feet. I don't mess around with unnecessary stuff, so I don't need much money. Von Dutch
Offline Triffecpa
Re: any gas tank sealer sold in stores
« Reply #1 on: August 16, 2007, 07:47:34 AM »
I've used some stuff that I bought at WalMart or the auto parts store.  Not sure which.  It comes in a yellow tube and is clear.  It's listed as "gas tank sealer" or something like that.  It seems to work pretty well if you let it set up for 24 hours or so before introducing gas into the tank.
Tracy
Offline rhinoracer
« Reply #2 on: August 16, 2007, 08:13:50 AM »
Don't know how bad you need it, but in an emergency you can use bar soap, the one used for clothes washing.
Knead a small ball of it like putty and seal the tank. Will last for years.
Baja native.
Offline Jonesy
  • Shop Rat
« Reply #3 on: August 16, 2007, 08:40:51 AM »
Permatex makes a gas tank repair putty that is a 2-part epoxy. It comes in a 5-inch stick that you break off what you need, knead it together and then apply it to the tank. It adheres well to aluminum and steel. (I used it once to repair a damaged fuel petcock).
Autozone usually carries a wide range of Permatex products.
Offline Geeto67
  • A grumpy
« Reply #4 on: August 16, 2007, 08:47:17 AM »
almost every radiator shop across the country carry some form or another of the popular gas tank sealers. the one I used to work at stocked both kreem and redkote (redkote is much better).
Maintenance Matters Most
  • stupid gloripope
« Reply #5 on: August 16, 2007, 12:01:23 PM »
called two radiator places by my house no go.
Offline kghost
« Reply #6 on: August 16, 2007, 12:07:47 PM »
How about a little more info...what exactly are you trying to seal?
I ask because just sealing a pin hole leak from the outside is a stop gap measure at best.
Pin holes develope from the inside out.
Generally in the back bottom part of tanks..where water and other contaminates sit...until they rust thru and create a leak.
Best way I have found is to weld them up with a mig or tig welder and then clean, acid etch, and reseal the tank.
I recommend POR-15 as the internal sealer.
Done right its never a problem again.
Epoxy sealing from the outside? works sometimes, and sometimes not...might hold a day, a month or a year...but generally not a hell of a long time...
Just my two cents.
Stranger in a strange land
johnny-from-bel
« Reply #7 on: August 16, 2007, 12:36:25 PM »
Pin holes can be soldered. I have done it with great success. Of course without treating the inside with something like POR-15 or rustbuster it is not a long lasting solution
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #8 on: August 16, 2007, 12:56:21 PM »
If you are talking pin holes, there could be some you can't see just yet. If you have some now, you might want to consider one of the acid etching solutions (which is one of the POR-15 kit steps) for the interior to reveal any others that are about to break through so they can be addressed before you seal the tank.
Offline gerhed
« Reply #9 on: August 16, 2007, 01:16:40 PM »
Had paper thin metal on left side tank of my Indian.
Gas was seeping through the metal !
Used 2 part Kreem on it 15 years ago.
No leak since.
          83 XL600R in CB360 Frame
