Author Topic: Valve adjustment for newly built motor  (Read 1725 times)
Offline Sweep
  • Just remember there are no stupid questions, just some idiot asking them.
« on: August 18, 2007, 01:31:17 PM »
I'm not sure what I could have done wrong, in fact I don't think I could have done anything wrong here.  I have an APE worked cylinder head with new valves springs, wiseco 836 pistons, and a Web 41a cam with .360 lift, 280 duration, and 260 duration at .050.
I can't even get the cam into a position to enable the stock clearances of .002 intake and .003 exhaust regardless of 1&2 TDC.  I can get it to a position to where the valves are not opening but I just can't get it to where I can get a feeler gauge in there at all.
Is this normal and/or what could be wrong?
Thanks.
'76 cb750K Wiseco 836|ape crank/head|Carillos|CR29s|Dyna 2k|Kerker
'74 Norton Commando Fastback w/belt and bells
Offline Sweep
Re: Valve adjustment for newly built motor
« Reply #1 on: August 18, 2007, 01:45:18 PM »
I think I blundered the cam timing and though I lined up the scribe and index lines on the cam 1&4 must not have been TDC.  That's what I get for not looking into the plug holes!
« Reply #2 on: August 18, 2007, 04:12:25 PM »
Are you using an adjustable cam sprocket?
Offline Sweep
« Reply #3 on: August 19, 2007, 04:55:40 AM »
Yes I am.  I was just being stupid or overly cautious and forgot the thousands of times I've adjusted valves on bikes.  I read the manual and took it that I needed to get the motor spun to 1-4 TDC (T mark) AND get the cam notch at 12 o clock when really all I needed to do was get both of number 1's valves to their most flat points, which of course put the notch at 6 o clock and confused me.
I re-timed the cam but it was right in the first place.
When I get this finished I'm immediately getting another cb750 donor so I can do this again, I'd hate to lose or waste the knowledge gained.
Thanks,
Sweep
« Reply #4 on: August 19, 2007, 06:46:43 AM »
Thanks,
Sweep
Good job figuring it out. ;)
Offline aptech77
« Reply #5 on: August 19, 2007, 07:02:36 AM »
You should not be using the "stock" clearances anymore. Web Cam's should have gave you new specs. to adjust the valves to. Mine was .004/.004
« Reply #6 on: August 19, 2007, 07:04:26 AM »
That's right...I overlooked that.
Offline Sweep
« Reply #7 on: August 19, 2007, 11:20:25 AM »
I did find that yesterday via searching this site and used those specs.  Thanks.
