Author Topic: engine rebuild help-cb400f  (Read 1767 times)
Offline stay youth
« on: August 22, 2007, 10:32:00 PM »
Hello im in the process of rebuilding my 400/4 engine, I was putting my oil pump back in the case and i went to get to proper new o rings from my athena rebuild kit and i could not find them. there are two small dowel o rings, 2 medium sized dowel o rings and one larger for the pump body. should these be included in a rebuild kit or do i need to go buy them separately? thanks!
1976 cb400f
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
Re: engine rebuild help-cb400f
« Reply #1 on: August 23, 2007, 09:13:30 AM »
Not all kits have every thing you need.  Always a good idea to have a supply of metric O-rings on hand.
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
Offline stay youth
« Reply #2 on: August 23, 2007, 01:10:19 PM »
ok i will pick some up thanks
1976 cb400f
Offline jevfro
  • 1975 CB750 K5
« Reply #3 on: August 23, 2007, 01:36:38 PM »
you ever use the cheap ones from HF?
I've been thinking of ordering some of these... I don't understand the size codes though, P3-P9,? ??? G45?  ???
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=91512
Offline kslrr
« Reply #4 on: August 23, 2007, 02:17:45 PM »
Nice set.  I got a small set from Auto Zone.
I do not know what the size codes are.  I'll bet TT does.  He seems to know most things if not all.
        1981 CB650 engine
Then 1972 CL175
        1964 Yamaha YGS-1T
Offline malcolmgb
  • What am I not? an
  • The BEST 400 four by far
    • malcnet
« Reply #5 on: August 23, 2007, 02:50:06 PM »
If you look in the parts book the 'O' rings are listed with their size, go to an engineering store they should be able to supply/order the correct seal for you.
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
