Author Topic: wrinkle paint  (Read 2264 times)
Offline cb650 bobber
  • Expert I ain't no stinken
  • stupid gloripope
wrinkle paint
« on: August 23, 2007, 09:25:28 AM »
has anyone used wrinkle paint on a tank...
"I make a point of staying right at the edge of poverty. I don't have a pair of pants without a hole in them, and the only pair of boots I have are on my feet. I don't mess around with unnecessary stuff, so I don't need much money. Von Dutch
Offline lennlen
Re: wrinkle paint
« Reply #1 on: August 23, 2007, 09:30:48 AM »
The previous owner for my bike used duplicolor truck bed liner on the tank and sidecovers.  It looked like matte black from a distance, and was relatively durable considering it came out of a rattlecan.
I recently resprayed it gloss black with 2k base coat, clear coat, as I didn't like the "ratty" feel that the bed liner gave the bike when inspecting it up close.  From far away, the wrinkle paint looked and help up great!
  • stupid gloripope
Re: wrinkle paint
« Reply #2 on: August 23, 2007, 01:00:13 PM »
did you sand off all the bedliner.
Offline lennlen
Re: wrinkle paint
« Reply #3 on: August 23, 2007, 01:10:38 PM »
Yes, it took a little bit of extra effort, but it did sand smooth, and was not especially hard to get through.
Offline grumburg
  • 74550, 76400F, 72 750 67S90, 68CL90, 65 s65 66 x6
Re: wrinkle paint
« Reply #4 on: August 23, 2007, 05:13:57 PM »
Secret to wrinkle paint is heat. Have done several MGB dashes that came out great. Do it on the hottest day of the year (like today and tomorrow) in direct sunlight.
Fonda Honda
750K4
Re: wrinkle paint
« Reply #5 on: August 24, 2007, 11:05:17 AM »
Ditto on the need for heat when doing wrinkle paint.
I use a heat lamp to get the item pretty hot before spraying.
Heat the rattle can, too (this is good advice for spraying anything with a rattle can. Heat the paint in a pot of hot water and shake frequently while spraying. It helps the paint to flow out.)
Leave the heat lamp on the item for 30 mins or so after spraying. The heat is what makes it wrinkle.
And post pics when you're done!
Offline Philly550K1
Re: wrinkle paint
« Reply #6 on: August 28, 2007, 10:42:26 AM »
does "popcorn ceiling/stucco texture" count?
