WHat makes this hard is that it sounds like the needles have been changed and maybe the main jets. Without knowing for sure, it is hard to say. I know a 77K did not have slotted needles.
SO here is what I say now.
try riding and get the rpms to at least 5000 then kill the engine right there. Pull the plugs and see what they look like. This will give an indication of the main jets rich or lean condition. We can go from there then without guessing so much.
Also, set your idle screw that is in front of the carbs bowls on the engine side, out 1.5 turns. This is standard for this year.
This screw controls FUEL for low speed, the earlier 750s the screw controlled AIR for low speed. On our 77 - 78 bikes, turning the screw OUT makes it richer.
So check your plugs like I said before and see what they look like. Clean them and then idle for a few minutes and see what they look like again.
We can then make sure we are on the correct path.
Dont you just LOVE 4 carbs!
