Author Topic: Gas Bottle Tuning  (Read 1627 times)
Offline m00ntan
Gas Bottle Tuning
« on: August 26, 2007, 07:44:55 PM »
I use a soda bottle with a cap I bought from an RC airplane dealer.  The hose and connectors are from Home Depot.  The laundry mesh is from the Dollatree.
I don't hook this up without finding the fire extinguisher.
How do you do it?
CB750K4
CB550K1
CM400C
eldar
Re: Gas Bottle Tuning
« Reply #1 on: August 26, 2007, 08:46:58 PM »
Geez I think you are too safe. :D I use a 20 OZ pop bottle with the bottom cut off and a brass fitting screwed into the cap. Then clear plastic tubing. A gallon jug of gas in case I start to run low in the bottle!
Works fine but not too safe now is it! But I cant see spending 30 - 50 dollars on a simple quart aux tank.
Offline m00ntan
« Reply #2 on: August 26, 2007, 09:02:33 PM »
Yeah, that $50 quart bottle said I could do better.
« Last Edit: August 26, 2007, 09:04:05 PM by m00ntan »
CB750K4
CB550K1
CM400C
Offline Gordon
  • 750K1, 550K2
« Reply #3 on: August 26, 2007, 10:18:05 PM »
I can usually get the carbs synched with the gas available in the bowls, but on the occasion I take a little too long, the air vent nipple on my one gallon gas can fits perfectly in the fuel line.  I just refill the bowls and go back to it.
Offline kghost
« Reply #4 on: August 27, 2007, 12:13:54 PM »
I screwed a petcock on the bottom of a one gallon marvel mystery oil can.
Stranger in a strange land
Offline HITMAN
« Reply #5 on: August 27, 2007, 12:21:29 PM »
Paging Dr. Camshaft...   Paging Dr. Camshaft...   Code-Honda in the driveway STAT!!! ;D
For mine, an old Honda 50 tank has been kept from the garbage pile for many years to do that with.
1974 Honda CB550F
1984 Honda GL1200A
2003 Honda CBR1100XX
Offline UnCrash
  • Pass
    • My Blog
« Reply #6 on: August 27, 2007, 12:30:27 PM »
Sheesh that sounds too easy.  Plus I think I take much longer doing it!
I may be doing it the hard way, but I built a quick sling for my tank, threw the other end of the rope over a joyst and hauled it up a few feet, connected some clear line and turned the petcock on.
« Reply #7 on: August 27, 2007, 02:17:50 PM »
I bought extra fuel line and inline couplers.  And then run it over to the bikes own gas tank sitting on saw horses next to the bike.
Offline Gordon
  • 750K1, 550K2
« Reply #8 on: August 27, 2007, 03:01:43 PM »
I'd try something like that, but then I'd forget about the fuel line strung over to the tank and trip over it, pulling my nice, undented tank down to the concrete floor.
I knocked a tank over once, and only once, which resulted in me investing in some HVLP spray gun equipment and learning how to do body work and automotive finishing.  Ever since then, my tank is either sitting on the bike, or on the ground. ;D
« Reply #9 on: August 27, 2007, 04:22:40 PM »
I learned a different lesson.  I used to use one of those TV stands for the tank.  Worked for years rather well.  Then one day I put a FULL tank on it while doing the sync thing.  Seemed okay.  2 minutes later while my back is turned reaching in the toolbox I hear a crash behind me and confirmed the reason why they call those TV stands collapsible.  DOH!
Do I get credit for keeping it undented for 25 years?
Offline my78k
« Reply #10 on: August 27, 2007, 07:22:05 PM »
Every so often I see somebody pitching out an old lawnmower on the side of the road. They usually have plastic tanks (maybe a litre or 2 at most in size) so if they fall tey don't dent or leak. I have 2 (not sure why I have to have a spare spare tank?!?!) and a 4 foot length of fuel line...
Dennis
eldar
« Reply #11 on: August 27, 2007, 07:26:05 PM »
An old lawnmower tank would be perfect I think. Just clean out the old crap since some of the old ones you have to mix the gas and oil.
Offline my78k
« Reply #12 on: August 27, 2007, 07:29:49 PM »
Oh yeah...one other thing...a pair of vise grips to act as a fuel shut off valve too! Forgot that the first time (also the only time I forgot it!)
Dennis
Offline mark
« Reply #13 on: August 28, 2007, 01:08:13 AM »
Found this NOS fuel tank at a yard sale years ago. Probably gave a quarter for it. Never used it as it only holds a pint. I think it is about to become a Honda tool! ;D
Time to scrounge a petcock and a hose tee.
Happy trails!
F you mark...... F you.
