Author Topic: what could be wrong with this bike  (Read 1950 times)
Offline cb650 bobber
  • Expert I ain't no stinken
  • stupid gloripope
« on: August 27, 2007, 06:05:50 AM »
My buddy wants a cheapy bike....There is a cb550 in the paper that says this.
It stalls if there's no choke
Even with full choke if you give it gas too quickly it stalls
Any Ideas what might be wrong with it.
"I make a point of staying right at the edge of poverty. I don't have a pair of pants without a hole in them, and the only pair of boots I have are on my feet. I don't mess around with unnecessary stuff, so I don't need much money. Von Dutch
Offline mmtsquid
Re: what could be wrong with this bike
« Reply #1 on: August 27, 2007, 06:13:34 AM »
Sounds like the carbs are dirty.
Granted, you never know until you take it apart........
77 CB550K4
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #2 on: August 27, 2007, 06:32:17 AM »
Ditto what Squid said.  Running with choke would be an indication of an overly lean carb setup.  Dirty carbs with plugged up passages could very well run lean.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
« Reply #3 on: August 27, 2007, 09:05:16 AM »
sounds like a 77/78 with blocked pilots to me
  • stupid gloripope
« Reply #4 on: August 27, 2007, 09:09:10 AM »
its an 83 cb550
« Reply #5 on: August 27, 2007, 09:40:23 AM »
its an 83 cb550
That's a DOHC4.  Likely with CV carbs, very different from earlier CB550s.  Still, a carb cleaning would be my first suspicion.  Perhaps a vacuum leak.  Didn't these have a vacuum operated fuel petcock?
At any rate, it is an "other bikes" category.
Offline ieism
« Reply #6 on: August 27, 2007, 09:56:38 AM »
I thought the last 550 was the K3 made in '78...Are you sure it's not a 650 ?, they still made those from 1980 - 1982.
Anyway, I agree with most here that's it's likely to be a carbissue. But it's hard to determine if the rest of the bike is any good if you can't really drive it. I would make a low offer to be on the safe side.
Also check for any missing parts, so you won't have spend a lot of money on new parts.
If it's a '78 550K3, or any other 550 with 4 pipes, take a real good look at the underside off the mufflers and headers. A lot of these are rusted really bad with holes in them, this comes from condensation that builds in the pipes (short rides).
These chrome 4-4 pipes are extremely expensive to replace, and a permanent fix is also difficult.
Other 550 parts that can be expensive or hard to find are: Front- and Rearfenders, lamp-ears, forktubes, sidecovers and tanks. So make sure these are ok.
---cb550---
Offline crazypj
  • I'm brill, me
« Reply #7 on: August 27, 2007, 11:35:39 AM »
 It looks like a mini version of the late model CB750 DOHC (the one with hydraulic tappets)
PJ
Offline KB02
« Reply #8 on: August 28, 2007, 04:53:16 AM »
http://www.motorera.com/honda/h0550/nighthaw/nighthaw.htm
There was a 550 Nighthawk for '83 and '84.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
