Author Topic: Hot Honda H2O cooled  (Read 1511 times)
Offline bozo4onion
« on: August 29, 2007, 11:46:13 AM »
Friend has 84 Honda V45 (I think 45) overheating. Any help. I told him radiators were a fad.
Thanks.
johnny-from-bel
Re: Hot Honda H2O cooled
« Reply #1 on: August 29, 2007, 01:10:22 PM »
Run lean = overheat
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #2 on: August 29, 2007, 01:15:09 PM »
Check (in this order)
1. Coolant level (don't ask...)
2. Thermostat
3. Pump
There's not a lot else to go wrong.
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
Offline mikedialect
  • cbjunky
    • Mike's Metric Vintage Honda
« Reply #3 on: August 29, 2007, 03:58:09 PM »
Is the fan turning on? I know the v45's of that era had fan switches that turned on too late to matter. There is a ton of info on the web about  modding them with a switch to turn them on sooner. Also, the thermostats were sub par. The list above is a good check, but the cooling system is known to be really inadequate.
SOHC4 Member#44153
www.mikesmetric.com | www.mikedialect.com
Offline DarkRider
« Reply #4 on: August 29, 2007, 07:16:29 PM »
I have yet to find any info for adding a switch to the V4 bikes...mind you i havent really been looking that hard just yet...but a better question is which model of V45 is it...The Magna, The Sabre or The Interceptor?
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Offline mikedialect
  • cbjunky
« Reply #5 on: August 29, 2007, 08:08:33 PM »
http://www.angelfire.com/ia/z/Z65magna.htm
some good stuff to consider on those guys...
SOHC4 Member#44153
