Author Topic: dual disc conversion tutorial(doco)  (Read 5710 times)
Offline cben750f0
« on: July 12, 2005, 07:39:31 AM »
here is a doco i did on the dual disc conversion.... any questions just ask...peace
http://www.sohc4.net/index.php/archives/52
[Note: I added this to the tech section on the website; takes up less room than a word doc; illustrations and formatting are as true to the original as I could get -- Glenn]
« Last Edit: March 16, 2011, 04:22:35 AM by Glenn Stauffer »
Offline Harry
    • CB500F
Re: dual disc conversion tutorial(doco)
« Reply #1 on: July 12, 2005, 08:19:49 AM »
Wow! Nice! Can I show this the honour it deserves and put it in the FAQ?
Harry Teicher, member #3,  Denmark....no, NOT the capital of Sweden.
Offline cben750f0
« Reply #2 on: July 12, 2005, 08:27:28 AM »
yeah if you like... go your hardest...i did it for anyone who wanted to have a go at it.... might want to link it to the caliper reversal topic.... part of the doco is relivant to the reversal topic..peace
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #3 on: July 12, 2005, 09:51:03 AM »
Off topic - 'doco' - where did this term originate?  I've got someone in the office (South African in origin) who uses the term 'docco' to refer to documentation.  I thought it was just him  ;)
eldar
« Reply #4 on: July 12, 2005, 01:37:08 PM »
ALright Ben, aside for the oddball aussie lingo, I think I got everything ;D
Now I notice you switched to a 500/550 speedo, In the pics, the speedo looks like the one I have on my 78K. Are you able to get measurements of the 500 speedo drive so I can compare it too mine? Does the new speedo drive bolt right up with no mods and no HUGE kmh/mph adjustments?
Thanks again ben, great work.
Offline cben750f0
« Reply #5 on: July 12, 2005, 02:10:13 PM »
should be a neat fit into the middle of the disc, and have a little tab on it so that it can be driven by the cut outs on the hub(you'll know what i mean when you pull the  old speedo drive off... the the only thing you are changing is the speedo drive plate, not the gear box, so the gearing to the speeod isnt changed...all a bolt on affair and away you go, well for the wheel anyway...peace
Ben
« Reply #6 on: July 12, 2005, 04:35:52 PM »
I dont think the term 'doco' is just an antipodean thing, I think it is just a carry on from the file extension .doc, as for word documents!
Offline cben750f0
« Reply #7 on: July 12, 2005, 04:39:48 PM »
HA :D ben that ben sounded really authorative!!!! :P... its just a term i had picked up somewere... but thanks for the explaination... 8)..peace
Online bryanj
« Reply #8 on: October 08, 2005, 09:02:11 AM »
There is a slight problem with this as the 500/550 speedo drive plate is exactly the same as the K1 onwards 750. The one that works is the VERY early 750 one now discontinued. The drive plate can be modified relatively easily with a vice, hacksaw and hammer, OK a file as well if you want it tidy. I have pictures of both if anybody wants them please PM me.
Offline IndianRider
« Reply #9 on: December 21, 2006, 08:42:43 AM »
bryanj ..can u post the pics here for all of us to see ?
Offline IndianRider
« Reply #10 on: December 21, 2006, 08:48:37 AM »
what if you dont want to or cant find a cb500/500 speedo .. will the stock '78 cb750k speedo still line up with the right disc and hub and allow for reinstallation of the wheel assembly ??
the speedometer might not work, but i can install a digital bicycle speedometer with the pickup magnet for my speed ...
« Last Edit: December 21, 2006, 08:50:16 AM by IndianRider »
Offline burmashave
  • Forum Immoderator
    • burmashave.net
« Reply #11 on: December 21, 2006, 09:05:16 AM »
Wow, Cben, you did quite a job in putting your doco (note gratuitous use of antipodean jargon) together!  I don't have plans for a conversion; however, this would make a great faq.  If you'd like, I'd be happy to do the minor effort required to post it with the faq's.
Quote from: SOHC Digger, RIP
'77 CB750k
Offline cben750f0
« Reply #12 on: December 21, 2006, 02:21:41 PM »
i think it is already in requently asked, under braking??....
along with the brake caliper reversal i did.....
 ;D   cheers
Offline burmashave
  • Forum Immoderator
    • burmashave.net
« Reply #13 on: December 21, 2006, 03:08:39 PM »
 ;D   cheers
See!  I told you it was a good idea.  ;)  ;)  ;)
'77 CB750k
