Author Topic: Advice wanted on starting up my new engine.  (Read 4894 times)
Offline sparty
  • I just play one on TV
    • Gallery
« on: September 03, 2007, 06:42:08 PM »
Guys,
There is the possibility that I will be ready to start up my new engine by next weekend or early next week or before the first snow fall. ;D  I am seeking advice on how to do it without any problems.
I still have a few things to do:
1. fit engine into frame - Wednesday
2. install oil cooler - when it gets here from Oz
3. install new Kerker exhaust with comp baffle
4. intsall CR carbs
5. hook up Dyna 2000 ignition and set timing
6. fit drive chain
Sparty
1972 CB750 K2 Cafe' Style
Re: Advice wanted on starting up my new engine.
« Reply #1 on: September 03, 2007, 07:00:32 PM »
Art
 Sent you an email.
« Reply #2 on: September 03, 2007, 07:02:03 PM »
Remember....you can start the engine with the original filter housing and filter......no need to wait for oil cooler adaptor etc.
« Reply #3 on: September 03, 2007, 07:08:44 PM »
I think I would put some oil or Marvel in the plug holes so you get a wet start.
Offline scondon
  • Mmmm......tasty bugs
« Reply #4 on: September 03, 2007, 08:14:26 PM »
 You are going to loooooove that engine,Sparty :)  I just got my CR's sorted out and on the bike and it is just stupid fast now  ;D
   I'm sure that Mike gave ya all the start-up details in his PM and since he built the beast I bet it's all good. Here's some stuff I learned from Mike and Sam.
    Use the old oil filter for initial start. It should catch the fine particals better than a new filter. Initial start will get your oil full of assembly lube, cam lobe coating and other stuff so you'll be changing the oil and filter in short order anyway.
     A quart of oil poured through one of the tappet covers will prime the return system so oil will fully circulate in a short amount of time. I'd like to say that I had full oil pressure instantly, but I know that's not the case. However, the pressure gauge read a solid 70lbs very quickly and did not waver. Before Mike taught me that one I would have a good five to ten seconds of surging/falling oil pressure when starting a freshly built motor.
      Most people I've talked to have said that the only lubrication needed on a fresh bore is to wipe it down repeatedly with the oil you will be running in the bike. This is done during assembly so unless the engine had sat for a year I would think it's good to go.
johnny-from-bel
« Reply #5 on: September 03, 2007, 10:23:03 PM »
Don't hydrolock the engine.
Offline KB02
« Reply #6 on: September 04, 2007, 05:10:53 AM »
You want advise? here's some advise:
   Hook up a video camera of some kind so that you can post a quick video of the maiden "Vroom."   ;) ;D
I just dropped my head off with Mike for a little bit of work. I already can't wait to get to the point that you are at right now.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
« Reply #7 on: September 04, 2007, 09:09:28 AM »
Hey Sean,
How about posting your set up. Meaning engine mods, exhaust, air cleaner system, which CRs and the final jetting and, of course, dyno if you have had it done.
Offline sparty
    • Gallery
« Reply #8 on: September 04, 2007, 09:09:55 AM »
How long do you think I should go before changing the initial oil? 200 miles or so?
Mike suggested I should use 10-40 oil for break in.
Thanks for the advice guys.
Offline angeldeville
  • You meet the nicest people on a Honda!
« Reply #9 on: September 04, 2007, 09:26:52 AM »
aside from sending it to me for a 100,000 mile "break in"
I'd leave it a quart low and add the final quart through one of the #4 tappet covers just prior to start up.
Put a few (10-15) drops of oil in through the plug holes, add old well gapped plugs.
Fire it up, tune it, spank the crap out of it for about 25-50 miles.
Then add new plugs, and new oil.
On a new engine I change the oil at 50 miles, 200 miles, and 500 miles.
and after that I change at 2000 mile intervals or 6 months, whichever comes first...
76' cb750f custom
69' cb750 sandcast
69' CT90
Amen Saviour 750 Chopper frame
and enough parts to build about 6-7 more bikes
Offline scondon
« Reply #10 on: September 04, 2007, 10:17:22 AM »
50-200-500 is exactly what I did too. The 200 mile oil change wasn't planned though, seems I buggered the 4th gear selector on assembly and had to split the cases to fix :P ;D
  SamCR750 swapped his oil after 20 minutes on the stand. I think the first couple of oil changes are to get all the assembly grease out, more so than debris. My oil looked like sludge at 50 miles and still had an odd sheen at 200. 500 miles looked more like it should and some fine metal powder showed up on the magnetic drain plug.
  10-40 is good for break-in 'cause it circulates so easily and you won't be treating the motor rough anyway. I've been running 10-40 on both bikes, but may switch to 15-40 or 20-50 on the new one since it does get hot with all that high rpm riding. I've been changing oil every 1500 after initial break-in period just to be on the safe side. At 3500 miles that is five oil changes so far :D
Hey Sean,
  Wil do, Rxman. The dyno will be done before Christmas. Just got the CR's on this weekend and am doing initial tuning. With the Dyna 2000 there are more variables to play with between ignition timing and jetting/clip position so it may take a bit for me to get things smoothed out. The weak link in my set-up is the Kerker can with no baffle( just a end cap ) and I hope to have a different pipe on by end of month. I've been watching Sparty's posts with interest 'cause we have similar set-ups.
Mine:
'78 750F motor
K7 head with stage 2 porting(Mrieck), oversize intake valves, Kibblewhite springs,Ti retainers
Webcam 63a cam
Wiseco 836 pistons
balanced/lightened crank(APE)
polished/balanced/shot peened stock F2 rods(Mrieck again)
Keihin CR 29mm carbs w/pod filters
Dyna 2000 ignition
Kerker can on Mac header, no baffle(no back pressure either, pooh)
   Initial tuning so far is:
  Dyna 2000: set on #4 advance curve with 38 degrees total advance timing
  Keihin 29mm:
    #62 pilots, mix screws at 7/8 turns
     Needles in middle clip
     #122.5 mains
  So far I've fixed some trouble with the starter circuit on the carbs and with these settings have good idle and great midrange. A little hesitation off idle and slow accel when I crack wide open. Think that mains will have to go above 125 with this exhaust which is why I'm eager to change it out before going much further on tuning.
  OK, sorry to hijack your thread Sparty. Keep posting your results as you get it up and running and I'll do the same ;) :)
« Last Edit: September 04, 2007, 10:24:22 AM by scondon »
Offline sparty
    • Gallery
« Reply #11 on: September 05, 2007, 06:40:37 AM »
I better buy a case of Castrol and a few oil filters this week.
I'll follow your 50-200-500 advice.
Sparty
« Reply #12 on: September 05, 2007, 10:39:02 AM »
Sparty,
Have you considered using synthetic after the Castrol break in? I have just experienced synthetic for the first time by switching my Fat Boy over. I already knew it was a good idea but expensive. You have an expensive engine. I haven't used it in my old Honda engine because, in this case, it seems a waste. I immediately noticed a MUCH improved shifting (tranny is a seperate unit on the Harley). I can easily find neutral now. I just returned from a 4130 mile trip on my Fat Boy. I was in the desert for 4 days. Temps up to 115 or more. Engine oil temps up to 270. Mostly 240 to 250. The oil has about 5000 miles now and it is only slightly discolored. My main concern was thermal breakdown in the intense heat but the oil has seemed to hold up well. I can't say I noticed a performance difference due to the oil. When I get the 2 expensive Honda engines completed and broken in I will switch to synthetic.
johnny-from-bel
« Reply #13 on: September 05, 2007, 10:41:06 AM »
Sparty
Do so if you can afford it. I buy oil by the 50 liter barrel :)
Offline scondon
« Reply #14 on: September 05, 2007, 10:48:35 AM »
Rxman,
  Which synthetic are you using?  There is significant heat generated in my engine and would like to try synthetic, but know very little about it.
« Reply #15 on: September 05, 2007, 11:27:51 AM »
My oil is that super secretive Harley SYN3. They will not divulge who the manufacturer is. I know how much has been discussed here about oil and I'm not about to start that #$%* again (hint hint everybody let's not go there PLEASE!) so suffice it to say I'd pick one that Honda recommends and I would not try this brand in my Honda. We have to remember that our Hondas use the same oil for the engine, clutch and tranny.
Offline scondon
« Reply #16 on: September 05, 2007, 11:44:26 AM »
   What, and miss the chance to open up a whole new can of #$%* by putting not only synthetic, but HARLEY synthetic, in my precious Honda :D :D    Kidding, when I get done with tuning I'll do a site search and ask over at Hayasa and see what others are using :)
Offline sparty
    • Gallery
« Reply #17 on: September 05, 2007, 12:14:00 PM »
I will eventually use a Synth oil in the bike.  Not sure which brand yet.
« Reply #18 on: September 05, 2007, 12:26:05 PM »
I still haven't tried going the synthetic route, because I'm cheap, but engines cost more than oil and a few filters.
76' cb750f custom
69' cb750 sandcast
69' CT90
« Reply #19 on: September 05, 2007, 12:35:09 PM »
 I use Honda HP-4 in all my bikes (semi synthetic)
Offline scondon
« Reply #20 on: September 05, 2007, 12:44:10 PM »
     Sparty, do ya have a plan on how to run the engine for the first 500-1000 miles of break-in?  Honda says to run their stock CB750 motors below 6000rpm for the first 1000 miles at varying speeds. Sam and Chris have been drag racing theirs after 20 minutes of idling. There's a few different schools of thought on this so would be curious as to what advice you received.
     I've got a lot of twisty roads nearby so usually will spend the weekend running through them at an easy pace. About 250 miles of varying speeds and engine accel/decel. After the first 20 miles I'll do a short, hot run up through the first three gears. At 500 miles I'll go up to 7500rpm, at 1000 miles I stop looking at the tach. Not giving advice, just wanting to compare notes.
  If it's good enough for the Million Dollar CB.................... ;D
« Reply #21 on: September 05, 2007, 01:08:02 PM »
Varying the RPM's really important and making sure the engine doesn't get to hot is another. The engine needs some load to seat the rings. Bursts through the gears is good. I also quickly cut the throttle from 5,000 or 6,000 for some good engine braking.
fuzzybutt
« Reply #22 on: September 05, 2007, 01:59:29 PM »
hell, i use revtech oil in my cb. been contemplating a switch to synthetic after the rebuild though. which one is safe to use with a wet clutch like in my 74 750k?
« Reply #23 on: September 05, 2007, 05:53:35 PM »
I use the Honda HP-4. It's semi synthetic. I have Spectro semi synthetic many, many times in the past too. Let's not start an oil thread (GULP!)
Offline RRRToolSolutions
  • I love old Japanese bikes!
« Reply #24 on: September 05, 2007, 07:11:31 PM »
I am 100% synthetic in every piece of power equipment I own. I use Motul (sold as Kawasaki) oil in the prescribed 10w-40. I use Mobile 1 in all of my cars, trucks, and even Klotz in my race outboard. I won't start another "oil" thread, but go back and do a search on some of my own experiments and you'll know why. My wife's Mercedes mandates it's use, all Corvettes, Vipers, and Porche autos mandate it's use - from factory fill. I don't believe in conventional break-in crapola.
Sparty, as Mike has told you (he told me about it), pour 1 quart down the #1 tappet hole. Pull the plugs and turn the engine over until you get oil pressure. If you don't have a gauge - I'll send you my Honda tool gauge tomorrow on loan so you can see when it's pressurized. I wanted several cycles of oil being pumped to all metal surfaces so I would spin it until it reached 30 psi (it happens in just 2-3 seconds once primed. I'd let it sit for 5-10 minutes and do it again. Install plugs with anti-seize and 14 lbs.
When I cranked mine up, she had oil where it should be - especailly those rod and main bearings. Still t this day - I'll turn the handle swith to "off" and either kick it over 4-5 times or will spin it over with the electric starter before ever touching the choke until I get 30 lbs oil pressure (my gauge is permenently installed). I will never give it a cold, dry start after watching the gauge. This pre-lube is something I wish all bikes and cars had.
My 02 -
Gordon
Kaws, Hondas, Yamahas, and Suzukis - especially Kaws
