Author Topic: trimming the fat from my 750 motor  (Read 2415 times)
alfabeast
« on: July 12, 2005, 06:15:38 PM »
Almost got the bike done, I spent a lot of time lightening the engine, I was trying to achieve a lean 60's look.
I removed the starter ring and motor, shortened the gen cover and trimmed back the motor housing and gear selector cover..
It was a lot of work for a subtle change.
Offline jotor
Re: trimming the fat from my 750 motor
« Reply #1 on: July 12, 2005, 06:26:21 PM »
Might try swapping those brass carb drain screws for some aluminum ones, too.  ;-)
No, really, it looks great.
I'd rather ride a Yamaha than eat worms.
Gallery.....http://www.sohc4.us/forums/index.php?topic=2254.0
Offline kghost
« Reply #2 on: July 12, 2005, 08:21:05 PM »
Really like that shortened gear cover!
Did you go to a lighter alt.?
Does that chain look a little rusty to anyone else? ;) ;D
Stranger in a strange land
Ben
« Reply #3 on: July 12, 2005, 09:57:18 PM »
Those cases look fantastic! Is that just a bead-blast finish?
Offline cben750f0
« Reply #4 on: July 12, 2005, 09:58:27 PM »
yep definitly rust there... :o... great job mate, you should leave a drawing for the shortened stator cover here somewhere... i am pretty certain that someone (me ::))would give is a try...peace
Offline Mark M
  • This is what the 10 year old me wanted for Xmas
« Reply #5 on: July 13, 2005, 08:45:05 AM »
Looks good.
Yes more info on the generator mod would be good, I've already done the gearchange myself.
;D ;D :o ;D ;D
In the UK anything over 40 years old only needs insurance and Fuel.
alfabeast
« Reply #6 on: July 13, 2005, 09:00:31 AM »
Rust??? that's 60's patina ;)
The cases are painted a metallic graphite colour. I cut the end of the gen cover off and bond the plate on to make it oil tight, four studs pull the plate on, sandwiching the alternator coil. The bonded part is not just a butt joint but is also around the part that goes inside the cover ....hard to explain without some pics of the inside of the cover.
alfabeast
« Reply #7 on: July 13, 2005, 09:03:37 AM »
some pics
« Last Edit: August 24, 2007, 06:19:08 PM by Glenn Stauffer »
alfabeast
« Reply #8 on: July 13, 2005, 09:07:41 AM »
Forgot: once the cover is on, I use a radius cutter on a milling machine to machine between the four bolt boss, I then blend with a dremel and emery paper.
I've dropped the bike on it's side and the cover faired better then a stock one.
Offline Mark M
« Reply #9 on: July 14, 2005, 02:31:56 AM »
Is this for your CR road bike? Did you have to adapt the flywheel or generator coil under the cover, did you remove the large starter gear behind them to make more space?
Lots of questions, but you have got me thinking.
I did look at the M3 CR replica cover but it's very expensive and as my CR
is also meant to be a road bike I need to generate enough power to run the Head/Tail lights.
cb750_chris
« Reply #10 on: July 14, 2005, 08:49:29 PM »
Too bad thier isn't much you can do on the other side.  This side has really been on a diet and it looks good.
alfabeast
« Reply #11 on: July 14, 2005, 09:24:01 PM »
Mark, I removed the starter gear and machined the rotor so it would push further onto the crank taking up the space left by the gear, I trimmed it down a bit but not much so it will still charge, I could probably have made it a lot smaller because I have no starter and hence a small battery.
I think therre is room to trim the othet side too, If you have a boywer ignition you can trim the case back because you don't need the space for the advance mech, also the clutch cover can be removed and the underlying case can be spruced up a bit, starting by removing the three legs that hold the chrome cover on, but trimming the left side does balance the motor:
Bobby
« Reply #12 on: July 15, 2005, 08:56:58 PM »
Alphabeast, you call that a diet?   ;)  I have trimmed the giant metal gas tank.  Eliminated the ponderous rear fender assembly and light fixture.  I have disposed of the enormous seat and gravity laden metal seat pan.  And it was still too heavy.  I yanked the burdensome front forks and triple tree, brake calipers, disk and the substantial front rim and tire.  Dispatched the hefty gauges and wire loom.  And it was still too heavy.  Exiled the lumbering real rim and tire and all brake components.  Foot pegs and controllers were cast by the wayside.   And it was still too heavy.  I finally removed the large square aluminum block nestled between the frame rails.  Now, my CB750 is very, very, very light.    ;)
« Reply #13 on: July 15, 2005, 09:38:48 PM »
But it just sits in the workshop now! ha ha ;D
the_genrl
« Reply #14 on: July 15, 2005, 10:02:10 PM »
HA yep.  thats some diet alright, you saved 100lbs without the engine!
