There really aren't any clutch adjustments that will compensate for the engine overpowering the clamping force/friction potentional of the clutch pack. However, if your clutch cable is badly out of adjustment (too tight) it could keep the pack from completely clamping down and thus allow some slip. You should always make the adjustment at the "clutch release arm" first, followed by a free play adjustment at the cables lower adjuster. Fine tune it at the upper adjuster making sure that you don't have to unthread it too far out of the lever body. . . . If your clutch is slipping, make sure that you are not using an automotive type oil in your bike with friction modifiers! Your clutch friction discs, plates, and springs might also be worn reducing the holding power of the clutch. If none of these things are the case, then your next step would probably be to install stiffer springs. Not sure what options are out there for the 650 however.
