Author Topic: 3rd try eliciting suggestions re: drag baffles for CB500  (Read 1384 times)
Offline gregwaits
  • Damn, riding a CB750 sure is fun!
    • waits music
« on: September 10, 2007, 08:09:51 PM »
3rd attempt at eliciting suggestions re: my muffler dilemma.
I am running straight drag pipes (4 into 1) on my '73 CB500K2 project. I have a Keag cannister, but I hate the profile. I dig the look of the drag pipes, but passing inspection is an entirely different matter.
Any tips? The o.d. of the pipe is so large that I can't seem to find any slip in baffles the correct size. Do you think a muffler shop could help me out?
I did buy a small drag pipe baffle out of the J&B catalog. It is too small in diameter, but maybe it could be modified?
1978 CB750K8; 1970 CB450
Offline Gordon
  • 750K1, 550K2
Re: 3rd try eliciting suggestions re: drag baffles for CB500
« Reply #1 on: September 10, 2007, 08:28:17 PM »
Did they change the motorcycle inspection restrictions in the past few years?  I don't remember them being so strict that an open exhaust would keep a bike from passing.
Offline kghost
« Reply #2 on: September 10, 2007, 08:43:10 PM »
Well hate to have you try three times.....
Might I recommend you post some pictures?
I for one am perfectly willing to look at them and maybe come up with ideas.
Some of them may be impractical or even hair brained...but something might work.
First thought....how about building your own glass packs? Many motorcycle suppliers carry repack material for Mufflers....
Perhaps a pipe of the appropriate diameter with holes drilled in it then wrapped with fiberglass packing material?
Stranger in a strange land
Offline mkramer1121
« Reply #3 on: September 10, 2007, 08:49:34 PM »
Or, run the 4-1 w/ the Keag canister for inspection, and swap it afterwards for the drag pipes...I know its  pain to change the exhaust, but after 7 or 8 times in a few days, it becomes second nature, believe me, I know..
Offline neil young
  • striving to be an
« Reply #4 on: September 10, 2007, 09:32:37 PM »
thats what i was thinking.swap em
1972 CB500 k1
1974 CB550
1977 cb 550
2008 Triumph Scrambler
Offline gregwaits
    • waits music
« Reply #5 on: September 10, 2007, 11:06:22 PM »
Thanks all....great suggestions. I guess I'll at least hang on to that Keag.
« Last Edit: September 10, 2007, 11:18:37 PM by gregwaits »
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #6 on: September 11, 2007, 12:10:56 AM »
if you can weld or at least know someone who can, making glasspacks is incredibly easy.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
masonryman
« Reply #7 on: September 11, 2007, 03:14:25 AM »
Here is a pic of what i made, they are very tunable by adding glass or more or less holes. I would make you a set if you can't get what you need, just sent me some specs.
Offline paulages
  • 1976 cb735
« Reply #8 on: September 11, 2007, 10:59:06 AM »
i made essentially the same thing, but i used perforated sheet metal for the baffle. my local steel yard sells it by the foot, but there are much more expensive sheets available at different percentages of openings. i used two short pieces of pipe at the ends, and just rolled the perf. sheet around them into a tube. i tack welded them, but you could also just use hose clamps. with a slip-roller and a light material for the outer tube/megaphone, you can make a really light muffler this way.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
