Author Topic: Best blasting material?  (Read 1093 times)
Offline SClay115
« on: September 11, 2007, 10:35:01 AM »
I am needing to blast my engine cases, and was wondering what you guys would suggest to use? I also need to do parts of my frame, and some other bits here and there. But I have heard if you go to abrasive on the cases, it can cause serious damage...so what do you guys think?
Steve
Offline nippon
    • Classic Cycle City
Re: Best blasting material?
« Reply #1 on: September 11, 2007, 11:14:52 AM »
Offline Bodain
  • I love the smell of fresh asphalt in the morning!
« Reply #2 on: September 11, 2007, 11:25:30 AM »
For aluminum engine cases. Glass beads are great....  When I want more aggressive cutting and paint removal from steel I use aluminum oxide....
2009 Suzuki TU250
2014 Honda Grom
1988 Yamaha FZ600
2018 Honda Ruckus
1971 Honda CB500
Offline 736cc
« Reply #3 on: September 11, 2007, 11:34:25 AM »
Vapor blast is the trick; its a wet-media.
Offline Steve F
« Reply #4 on: September 11, 2007, 01:03:30 PM »
Steve
C-4
Offline greenjeans
  • 1972 CB750K2
« Reply #5 on: September 11, 2007, 01:35:22 PM »
I've used glass beads with good results.
Just got some walnut shells and soda that I'm going to experiment with on the side covers etc.
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« Reply #6 on: September 11, 2007, 05:43:24 PM »
I recommend Glass beads, it leaves a nice finish for paint too.  just make sure you get every last little glass bead out of the engine before you put it togeather.
That stuff will cut through bearings like they were made of cardboard ;)
 Matt.
Gallery at:
Offline hymodyne
« Reply #7 on: September 11, 2007, 06:16:32 PM »
I used a masonry? product called black beauty. it was more coarse than fine play sand but would still pass through my old sears and robuck  sandblaster nozzle. I only used it on the frame...
hym
