Author Topic: mirror threads are shot  (Read 1064 times)
retrogrrl
« on: September 11, 2007, 01:25:51 PM »
I just took my cover off and guess it yanked on the mirror.  wasn't hard BUT now the threads are shot and the mirror just spins around.  I NEED to go somewhere in 2 hours, i WILL need to replace the piece,
So my question IS:
what can I do to hold it in the meantime so it,
1) stays
2) won't ruin the threads on the mirror so I can re-use it...
(if I don't decide to go with the bar end mirrors after this)
thx all
Offline 736cc
Re: mirror threads are shot
« Reply #1 on: September 11, 2007, 02:47:18 PM »
maybe add a 2nd nut to threaded shaft as a locknut
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« Reply #2 on: September 11, 2007, 05:38:30 PM »
Bit late to help, but the extra nut on the bottom works well, I've done it. And if it still spins than put a little Teflon tape on the threads and jam it on there with the nut too.
Temporary fixes of course, might be able to put a heli-coil in there to restore the threads for a more permanant fix.
 Matt.
Gallery at:
Offline Jonesy
  • Shop Rat
« Reply #3 on: September 11, 2007, 06:55:13 PM »
I've done the heli-coil trick for mirrors and it worked like a charm.
Loctite also make a liquid thread restorer, but I've never tried it and it's doubtful I ever will...
Offline MoTo-BunnY
  • The 'Torque 'er Down 'till it Strips Then Back 'er Off a Quarter Turn', Type of
  • 1973 CB500 ~ member #3791
    • http://instagram.com/moto_bunny#
« Reply #4 on: September 12, 2007, 02:27:10 AM »
a pinch o' coarse steel wool kinda wrapped around the threads will work to get them to grip, at least temporarily.
(heli-coil is the real solution though, for sure. ... )
---> instagram.com/moto_bunny# <---
[img width= height=]http://farm4.static.flickr.com/3440/3846213109_ae572002d4_o.gif[/img]
hoppin' on down the bunny trail . . .
1973 Honda CB500K2
1970 Ding-How aka Nova R-S w/3.5HP Tecumseh MiniBike
1970 Taco Model 22 deluxe w/3.0HP Briggs & Stratton MiniBike
1973 GMC Vandura 3/4 Ton Van (350CID V8)
1973 Dodge "Chinook" RV (360CID V8)
1985 Toyota Tercel Wagon SR5 (4WD - 3A engine)
1982 Toyota Pickup Truck (2WD - 22R engine)
1962? DriveX Pack-Mule (Tote-Gote clone)
1989 VW Jetta GLi 16V
1991 Diamondback Mtn. Bike
drag0n
« Reply #5 on: September 12, 2007, 02:49:00 AM »
is it the threads on the mirror or the threads on the bars ?  if its the bar side thats stripped you could always find somebody that had a tap and die set to retap it for you  i doubt you could do that in two hours but its something to think about beyond the temporary fix
peace out
Jimmy
