Author Topic: largest tire size for cb 350 twin  (Read 26243 times)
Offline cb(r)
« on: September 12, 2007, 06:00:47 AM »
does anyone know what the widest tire you can fit on a stock cb350 rim?
or the widest tire you can use with another rim?  please specify what bike the rim came off of.
I am not looking to extend the front gear out or adding an idler gear somewhere or anything crazy like a couple of people I know have suggested.  kinda scares me.
I will however consider changing swingarms or something like this.
later
key
blantonator
Re: largest tire size for cb 350 twin
« Reply #1 on: September 12, 2007, 04:34:17 PM »
measuring the rear swingarm, you could easily go with 110mm... 120 is a big maybe, i'd be curious if it would.  The wheel measured at 3" wide, so that might be worth upgrading to a 3.5 or 4?
Offline crazypj
  • I'm brill, me
« Reply #2 on: September 12, 2007, 10:07:06 PM »
measuring the outside width is meaningless. The stock rim is only 1.85" inside so any wider tyre bulges upwards which leads to instability and fast tyre wear. I've used old motocross wheels  to get 2.15 alloys rims cheap. You can easily fit a 3.50~3.75 inch tyre without excessive sidewall flex
PJ
Offline Raul CB750K1
« Reply #3 on: September 12, 2007, 11:48:12 PM »
I have a 4.00-18 fitted in my CB350, but only because that's what the PO fitted. It is almost new so I keep it for the sake of cost-efficiency, but I know I will have trouble going through the DMV inspection. The increase in width is not that big -for the looks factor-, so as soon as I replace it I will fit the original size.
Offline cb(r)
« Reply #4 on: September 13, 2007, 05:18:44 AM »
PJ
thanks pj,
always a wealth of knowledge.  I think I have an old aluminum rim in the shed.
Offline cb(r)
« Reply #5 on: September 13, 2007, 05:20:11 AM »
thanks raul,
you hit the nail on the head.  I was mainly checking for the looks factor.
Offline mikedialect
  • cbjunky
    • Mike's Metric Vintage Honda
« Reply #6 on: September 13, 2007, 09:46:20 AM »
thanks raul,
3 of the 350's I've had the PO's put a 4.00 tire on back and I thought it looked absolutely silly. I've swapped them all out with 100/90-18's. I recently put a 100/90/18 on the front to match the back and I think I have found- for me- the perfect size for my 350's.
SOHC4 Member#44153
www.mikesmetric.com | www.mikedialect.com
blantonator
« Reply #7 on: September 13, 2007, 10:06:59 AM »
what tires are you guys running.  I want to run the bridgestone bt45's but the smallest the rear comes in is a 110(4.3").  What are my other options... i want the "sportiest" tire i can get for the bike.
Offline mikedialect
  • cbjunky
« Reply #8 on: September 13, 2007, 09:28:08 PM »
I run chen's because I'm cheap. Someone on the hondatwins.com site was recently talking about how they liked the bridgestone battleax's a lot. I don't ride my 350's very hard, so I'm ok with chens.
« Last Edit: September 13, 2007, 10:42:10 PM by mikedialect »
SOHC4 Member#44153
Offline 333
  • Time for change
« Reply #9 on: September 13, 2007, 10:02:38 PM »
Where did you get 4.3?  A ruler?  The tire conversion chart is closer to 4.00 to 4.25 for rear tires.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline crazypj
  • I'm brill, me
« Reply #10 on: September 14, 2007, 01:09:21 AM »
110mm divided by 25.4mm= 4.330". 25.4mm= 1inch
PJ
Offline ohiocaferacer
  • www.OHIOCAFERACERS.com
    • OHIO CAFE RACERS
« Reply #11 on: September 14, 2007, 04:25:58 AM »
I run 110 on the rear of all my CB350's......and 100's on the front....stock rims.
blantonator
« Reply #12 on: September 14, 2007, 05:10:28 AM »
any pictures of the setup ohio?
Offline cb(r)
« Reply #13 on: September 14, 2007, 10:10:46 AM »
goto his website he has some nice bikes!
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
« Reply #14 on: September 14, 2007, 11:16:35 PM »
I know it's not a 350, but I stuffed a 120mm on the rear of my CB450 Project --->
Offline cb(r)
« Reply #15 on: September 15, 2007, 07:27:58 AM »
teal,
that looks cool.  what tire are you running on the front?
can you post a couple of pics of that exhaust?
also are your using a gel battery under the seat?
Offline ProTeal55
  • Est1968.com
« Reply #16 on: September 15, 2007, 11:33:06 AM »
teal,
The front is a 100/90/19 and the rear is a 120/80/18 Avon RoadRider tires.
A complete step by step build of the bike can be seen below ---->
http://www.sohc4.us/forums/index.php?topic=15615.0
Happy reading.... ;D
Offline cb(r)
« Reply #17 on: September 17, 2007, 05:41:41 AM »
Man,  where have I been?  Nice job teal.  happy riding!
Offline ProTeal55
  • Est1968.com
« Reply #18 on: September 17, 2007, 11:26:44 AM »
Thanks for the kind words..
The CB450 project turned into a bike I bought to semi cafe and sell to a bike that is now known all over
Chicago !
Next project is a CB360 I am gonna turn into a hardtail'ed bobber deal-e-o  ;D
Offline cb(r)
« Reply #19 on: September 17, 2007, 12:23:40 PM »
cool man
cant wait to see pics!
luvhonda750
« Reply #20 on: September 18, 2007, 09:39:05 AM »
I'm running a Bridgestone 110 on the rear, it fits with some slight margin, I think its the perfect tire, not sure a 120 would fit?
