Author Topic: 1979 cb650 tank on a 1980 cb650  (Read 1502 times)
Offline cb650 bobber
  • Expert I ain't no stinken
  • stupid gloripope
« on: September 14, 2007, 05:15:55 AM »
I am still trying to figure out how easy this would mount up I am back to getting one of these because they go a lot cheaper then the 1980 tanks.
"I make a point of staying right at the edge of poverty. I don't have a pair of pants without a hole in them, and the only pair of boots I have are on my feet. I don't mess around with unnecessary stuff, so I don't need much money. Von Dutch
Offline cb650
Re: 1979 cb650 tank on a 1980 cb650
« Reply #1 on: September 14, 2007, 04:14:55 PM »
I wanted to do this as the 79 tank is larger.   The rear mount is located farther back on the 79.  Can be done with a little work if really needed.  It would be easier to use a 81/2 tank and put a line adapter in.  Guess my 80 tanks arent good enough.
                     Terry
« Last Edit: September 14, 2007, 04:18:34 PM by cb650 »
Offline Soos
« Reply #2 on: September 16, 2007, 03:53:45 PM »
Juat tried to do this out of curiousity, and it would be possible if you bade a adaptor plate of sorts.
mount the plate to the existing mount hole, plop on the new ('79) tank, and mark where you need your mount hole.
remove plate, drill new mount hole.
However you will have problems with the stock '81 seat pan interfering with the new tank.
Unless you are willing to replace your seat/modify seatpan and re-cover, this is a bad idea....
and the '79 seatpan mounts WAY differently, unless your willing to modify it too.
l8r
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
Offline Soos
« Reply #3 on: September 16, 2007, 03:54:32 PM »
Mind you I was mounting a '79 tank on a '81 frame.(cb650)
l8r
-=≡ Soos ≡=-
Offline cb650
« Reply #4 on: September 17, 2007, 04:30:31 AM »
80/81 frames are the same.
                    Terry
