Author Topic: Saved again, thanks guys  (Read 1230 times)
Offline spitfire
« on: September 14, 2007, 05:33:55 AM »
Well still having a few teething problems with the 76 CB750F1, but everytime I have a problem I either do a search on this forum or post my problem, don't think I could have got this far without the advice and encouragement I have recieved.
The latest problem was the tacho drive oil leak, it got worse, so I did a search and found the answer on the famous JohnK6 "How to rescue a CB750 from the garbage dump" thread, boy that should be saved somewhere.
Used a wood screw as advised and out popped the oil seal, 10mm 1/4 drive socket and in went the new one, as stated 5 minute job.
As to the Master cylinder problems I had, see the pic below of what happened after I accidently put fork oil instead of DOT 4. I could not believe the seal would swell to this extent, but the eagle eyed amongst you will spot the piston marks on the seal that have grown as well.
Cheers
Den
Removing the tacho seal
Contaminated seal and old seal
Wirral UK
1976 CB750F1 bought new in 76
1977 CB750F2: Restoration started
1964 BSA A65R: Waiting restoration
My gallery is here: http://www.sohc4.us/gallery/v/members/personal/spitfire/?g2_navId=x5a30f7b6
Asimo
Re: Saved again, thanks guys
« Reply #1 on: September 14, 2007, 09:17:19 AM »
 ;D Oil makes rubber swell up Den. Heat will make it shrink back to
normal but as you have binned the bits no matter its easily done
Book yourself into Spec Savers regards Paul ;D
