Author Topic: K0 speedo/tach needle removal  (Read 1047 times)
Swoop
« on: September 16, 2007, 10:17:59 AM »
« Last Edit: October 26, 2009, 05:22:04 AM by Swoop »
Offline Swede
Re: K0 speedo/tach needle removal
« Reply #1 on: September 16, 2007, 03:45:16 PM »
If it is like the ones on my 550 then just use two spoons as levers.  Mine popped right off with no problems.
Offline Johnie
« Reply #2 on: September 16, 2007, 06:32:34 PM »
Swoop...how did you get the back off?  It looks like my KO has some sort of caulk seal holding the tach on.  I also wanted to get under my speedo glass and there is a plastice ring on the bottom that looks like it may break if I mess with it.  So I lubed the gear and put it back together.  Have you ever removed the speedo guts from the plastic and glass housing?
Thanks
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Johnie
« Reply #3 on: September 17, 2007, 05:02:27 AM »
Got it Steve and thanks.
John
Oshkosh, WI  USA
