Author Topic: Won't Start after pressure washing...  (Read 4460 times)
brentnclemson
« on: September 17, 2007, 06:59:02 PM »
So I took the bike to a DIY car wash today to try and clean up the engine a bit.  I mostly sprayed the cooling fins and front of the engine w/ a few sprays underneath.  Only washed it for a few minutes and sprayed it off.
Afterwards it wouldn't start...you could hear it trying, but...nothing.  Finally got it started w/ a lot of throttle, but it died at the first light.  Let it sit for a while and was able to get it running long enough to get home a coupe miles away.
After sitting for several hours it still doesn't want to start easily and dies w/out giving it some throttle.  It's almost acting like it's out of gas (yes, I checked!).  Any idea what would cause this?  What could get wet that would cause this?
Thanks guys!
Offline jtb
  • An unlikely
Re: Won't Start after pressure washing...
« Reply #1 on: September 17, 2007, 07:02:07 PM »
Points, plug wires, coils.
1977 CB750F
1985 V65 Sabre
« Reply #2 on: September 17, 2007, 07:33:10 PM »
Pressure washing is a great way to kill a motorcycle. Not only does it wash away dirt, but also vital lubricants in wheel bearings, swingarm bearings, steering bearings, etc etc.
More dirt bikes die as a result of pressure washing by over-zealous owners than almost anything else. Cheers, Terry.  ;D
brentnclemson
« Reply #3 on: September 17, 2007, 08:14:36 PM »
Well, I avoided places on the bike that require lubrication...and I thought I stayed away from the electrical components...  Mostly just trying to get the gunk out of the cooling fins, but that didn't even work...
brentnclemson
« Reply #4 on: September 17, 2007, 08:21:09 PM »
If you pressure washed it water can easily foul a plug.  Swap those out and see if you have spark, then go from there.
Will do, that was on the list anyway...thanks!
Offline MoTo-BunnY
  • The 'Torque 'er Down 'till it Strips Then Back 'er Off a Quarter Turn', Type of
  • 1973 CB500 ~ member #3791
    • http://instagram.com/moto_bunny#
« Reply #5 on: September 17, 2007, 09:32:56 PM »
Might want to drain your float bowls, too.
I made the mistake of using the pressure washer once, too, and after that, even after letting it dry in the sun, it ran like crap. .  .sporadically running on just 3 cylinders and what not. (the #2 exhaust pipe was only a bit warm after running while the others were way hot as usual)
I went through ALL the electrical stuff but nothing seemed to work. Finally, after having tried everything else, I drained the carb float bowls into a glass, one at a time. 3 of the bowls had just tiny drops of water in them, nothing that bad but the #2 carb bowl was like half water?!?   :o (this was even after having driven it around 5 miles, too!)
Don't ask me how it got in there. . .I still don't know because I didn't spray the top of the gas tank down or anything, but that water  sure as heck got in there!   ::)
---> instagram.com/moto_bunny# <---
[img width= height=]http://farm4.static.flickr.com/3440/3846213109_ae572002d4_o.gif[/img]
hoppin' on down the bunny trail . . .
1973 Honda CB500K2
1970 Ding-How aka Nova R-S w/3.5HP Tecumseh MiniBike
1970 Taco Model 22 deluxe w/3.0HP Briggs & Stratton MiniBike
1973 GMC Vandura 3/4 Ton Van (350CID V8)
1973 Dodge "Chinook" RV (360CID V8)
1985 Toyota Tercel Wagon SR5 (4WD - 3A engine)
1982 Toyota Pickup Truck (2WD - 22R engine)
1962? DriveX Pack-Mule (Tote-Gote clone)
1989 VW Jetta GLi 16V
1991 Diamondback Mtn. Bike
« Reply #6 on: September 17, 2007, 10:46:29 PM »
Fisrt place I'd look is in under the points cover.  Water in there condenses on the points, rendering one or both sets useless.  The cycle repeats next time you run the bike.
Make yourself a neoprene cover gasket from hardware store sheet goods. they seal better and can be reused for years.
Offline mrbreeze
  • Not your average
« Reply #7 on: September 17, 2007, 11:23:32 PM »
Motobunny-----you should drain your carbs quite often (Oregon= lots of rain=excess moisture) !!!!   Lloyd.......right you are as usual.....moisture in the points compartment makes for a sh!t runnin' motor!!!!! Remove cover....remove moisture.....install proper gasket....and finally.....DON'T use pressure washer and expect to ride away from the car wash!!!!! Ain't life grand out here on the west side??
MEMBER # 257
Offline 333
  • Time for change
« Reply #8 on: September 18, 2007, 12:01:28 AM »
Ditto on the points cover.  That cork isn't waterproof at all.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline spitfire
« Reply #9 on: September 18, 2007, 04:37:25 AM »
Take your tank off and wipe/spray your coils, leads and plug caps with WD40, check your points cover, and as already been metioned drain your float bowls.
Cheers
Den
Wirral UK
1976 CB750F1 bought new in 76
1977 CB750F2: Restoration started
1964 BSA A65R: Waiting restoration
My gallery is here: http://www.sohc4.us/gallery/v/members/personal/spitfire/?g2_navId=x5a30f7b6
brentnclemson
« Reply #10 on: September 18, 2007, 05:22:05 AM »
Don't use pressure washer...check!
I'll also drain the float bowls and check under the points cover this evening...thanks guys!
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #11 on: September 18, 2007, 06:59:58 AM »
I add a little hi-temp grease to the points cover gasket to help keep those mean 'ol water molecules away from my points!
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
« Reply #12 on: September 18, 2007, 02:03:08 PM »
And if you buy one of Hondaman's brilliant ignition amplifiers, you'll never need to adjust those old points again anyway, so you could silicone seal your points cover and, like they say in the Soprano's, "forget about it"! Cheers, Terry.
Offline mrbreeze
  • Not your average
« Reply #13 on: September 18, 2007, 09:02:19 PM »
Absolutely!!!!!!!!!!!!!
MEMBER # 257
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #14 on: September 18, 2007, 09:54:35 PM »
Your not the 1st one to do this............I've done that 1 1/2 hour dry time at a car wash when I got my 1st CB..
When I wash them now I use mist on the garden hose on the  the engine area, and the one notch just above that on the rest of the bike.
I used some gasket seal on the points cover "elect ignit in it now"  for new build to try to keep it dryer.
Good luck, enjoy the learning curve and have FUN!
« Reply #15 on: September 19, 2007, 04:13:45 AM »
Here you go mate, I've got Hondaman's "test" ignition on my K0 at the moment, and I bought two more, (one for my K0 after I finish the testing, and one for my K2) and I'm very happy! Cheers, Terry. :)
http://www.sohc4.us/forums/index.php?topic=22252.30
brentnclemson
« Reply #16 on: September 19, 2007, 04:55:28 AM »
Thanks for the help, guys!  New to CB's and motorcycles here!
Changed the plugs, drained the carbs and she's good to go!  Still haven't gotten the crud out of the cooling fins, though... ::)
« Reply #17 on: September 19, 2007, 05:08:32 AM »
Get some bottle brushes and some soapy water, then just rinse them off mate, much safer than pressure washing! Cheers, Terry. :)
