Author Topic: Nor Cal newbie  (Read 1330 times)
Jbird
Nor Cal newbie
« on: September 18, 2007, 10:03:58 AM »
Just thought I'd intro myself before I toured the site. I'm a 58 year old male with the body of a 55 year old. I live just outside of Sacramento CA. I just picked up two CB750s, a 72 that has been all choppered up and an almost stock 76. Both bikes have been sitting for quite awhile. I got the 72 running, it sounds pretty good even though the intake ruibbers are split. I'm gonna try to start the 76 tonight. I put a couple of squirts of Marvel Mystery oil in each cylinder yesterday. The 76 will be the restoration the 72 will be sliced and diced into something unatural but appealing. Wish me luck,   Jbird 8)
Offline dusterdude
Re: Nor Cal newbie
« Reply #1 on: September 18, 2007, 11:16:25 AM »
welcome,im a 47 year old with a 50 year old body.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
antiq
Re: Nor Cal newbie
« Reply #2 on: September 18, 2007, 11:24:26 AM »
A resounding welcome to you! I'm a twenty year old with thirty years experience and a beer belly! I just got back to riding again last spring after twenty plus years of dealing with family crap.
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
Re: Nor Cal newbie
« Reply #3 on: September 18, 2007, 11:36:25 AM »
Welcome from SoCal.  I guess I would be an 18 yo in a 46 yo body, which means that my 15 yo twin boys were born when I was mentally 3 (and my ex would agree).
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
Offline cafe75-550
Re: Nor Cal newbie
« Reply #4 on: September 18, 2007, 12:27:20 PM »
Welcome Jbird! I'm also in the Sacramento area, with a couple of 550's. One parts bike that may get put back together one of these days, and a cafe racer/perpetual project. Lets see some pics of those bikes!
My cafe project...
New bike!
'07 Triumph Speed Triple 1050
Never enough projects!
'75 CB550 "Cafe", '76 CB550 parts bike
'64 Norton Atlas featherbed/'71 Triumph 750 Triple (Triton project)
'68 BSA Thunderbolt (frame and cases, project in the wings)
'57 Triumph Thunderbird (frame and mostly complete engine)
Jbird
Re: Nor Cal newbie
« Reply #5 on: September 18, 2007, 08:01:40 PM »
Thanks for the welcome guys. I got the 76 cranking over tonite, I had to jump the solenoid. I think the ignition switch is toast. Where do I go to find out how to hotwire the ign sw? I'll snap a couple of pics and post them tomorrow..... nite all  Jbird 8)
Offline mrbreeze
  • Not your average
Re: Nor Cal newbie
« Reply #6 on: September 18, 2007, 11:09:39 PM »
Welcome to the site there Jbird. Mrbreeze from Modesto here. Most of the others from the area are out towards the bay area. Keep in touch with your revival posts and if you ever venture away from Sac. area give a holler.....always up for a putt!!!!!!!!!
MEMBER # 257
antiq
Re: Nor Cal newbie
« Reply #7 on: September 19, 2007, 07:02:37 AM »
Jbird a good wiring diagram will show you what wires to connect for power and which to connect temporarily for the starter. It may be that all you need is to take the switch apart and clean it. Be very careful though ,there are little springs and detent balls that want to jump out and get lost. Good luck!
Offline canyon750
Re: Nor Cal newbie
« Reply #8 on: September 19, 2007, 07:09:08 PM »
Breeze is talking about people like me in El Cerrito.  Most of us would drown a puppy to get some people together for a ride!   :o  OK, that was a bit extreme but you get the idea.   ;)  Welcome and keep those pictures and reports coming!
1976 CB750F (Modified!!)
2005 Honda VFR800 (Burnt & gone...)
2007 Honda VFR800 (RWB!)
2019 Yamaha Tracer 900 GT
SOHC/4 #846
Jbird
Re: Nor Cal newbie
« Reply #9 on: September 20, 2007, 08:10:22 PM »
Here's a couple of pics as promised. Not real purdy but good restorable bikes, well the 76 anyway. I got the 76 fired up tonite. It tried to start after I squirted some gas into the carbs but then the starter quit cranking the engine. The starter would spin but the engine wouldn't. I pulled the alternator cover off to change the starter, about a half quart of oil poured out onto my spotless shop floor (see photos). I found the bolt that holds the alternator rotor to the crank had loosened, the rotor and starter ring gear spun freely. I tightened up the bolt (impact wrench very carefully) and everything seemed normal. I got it ready for another starting attemp. I added a qt of oil just in case. It fired up and ran smoothly and quietly, I only ran it for a few seconds. Now I have a concern about the oil in the alternator case, is this normal?? Now I have to decide which one to mothball while I work on the other.  Jbird
