Author Topic: Wheel size for a CB750 Cafe Racer  (Read 12286 times)
Offline DORIGTT
« on: September 20, 2007, 06:47:27 AM »
Hello all,
I'm planning to build a Cafe Racer out of my 73 CB750 and I would like to know what wheel sizes are the 'norm' for getting 'good tires' for it and to keep the look 'right'?
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
Re: Wheel size for a CB750 Cafe Racer
« Reply #1 on: September 20, 2007, 07:22:24 AM »
Stock is 19 front and 18 rear..
Some people change this up (depending on the look they are after).
I had a 21'' front and 16'' rear on my CB750, but I kinda do things differently  ;D
My CB450 is running the stock 19'' front and 18'' rear -->
I just went a size wider out back to fill in the space as much as I could.
Offline DORIGTT
« Reply #2 on: September 20, 2007, 10:22:58 AM »
Is there any advantage to what you've done with the second bike as far as handling is concerned?
Is getting a wider rear wheel as simple as just getting a wider hoop?
What's an acceptable width to go to without having too-much tire for the chassis?
« Last Edit: September 20, 2007, 10:24:32 AM by DORIGTT »
Offline Irishguy
« Reply #3 on: September 20, 2007, 10:48:13 AM »
My opinion...
Smaller diameter back wheel + bigger diameter front wheel looks more like a chopper or bobber.
About same size wheels look more like a cafe racer.
Having said that...   Mine has the smaller back and the larger front.  But my rims and tires are both excellent condition and the back tire is nice and fat, so I'm not going to change it.  Plus I think the off-set wheels look more vintage.
Offline Six
  • Lucy - CB750F Cafe Racer
    • Motorcycle Diary
« Reply #4 on: September 20, 2007, 10:56:04 AM »
I changed wheels along with a whole new suspension system front and back in my cafe '750, and chose a 17" front rim and an 18" rear.  The 17" lets me fit a custom alloy fender AND fork brace (something I'm struggling with on the K-bike).  I can adjust rake in the front (since the goldwing tubes are longer than the 750's) by moving them up or down on the triple trees.  The bike turns quickly without a lot of effort, and very smoothly, more neutral than my '78K bike which seems to plow-in on slower turns.  On the rear, I used an aftermarket swingarm that allowed me to install a 140 width tire AND get a shorter wheelbase by 2" (both tires are Avon).  I had to shim the sprocket and machine new spacers, but everything just clears.
Enjoy!
Six - Minneapolis.
Offline ProTeal55
  • Est1968.com
« Reply #5 on: September 20, 2007, 01:33:52 PM »
The only reason I went wider on the rear tire of the CB450 was for looks.
The original/stock size tire left way too much room in the swingarm for my likin, so I went a size wider.
You can usually get away with a size larger on the stock wheels without running into any issues..
Offline DORIGTT
« Reply #6 on: September 20, 2007, 02:07:17 PM »
What manufacturer of rear swingarm six?
Offline lofathd
« Reply #7 on: September 20, 2007, 04:43:52 PM »
does anyone know if i can run 19" on the front and rear of a 76 cb550? is there any clearance issues with the rear tire or would i just get a lower profile rear tire?
thanks
Offline ProTeal55
  • Est1968.com
« Reply #8 on: September 21, 2007, 06:06:41 AM »
thanks
I am sure you could, just need to figure out a smaller diameter tire to make up for the increase in wheel size.
I really wanna build a bike with dual 21'' wheels for that tracker look (maybe over the winter)...
Offline Six
    • Motorcycle Diary
« Reply #9 on: September 23, 2007, 05:51:22 AM »
I'm not sure, got it through Ebay, it has 3 shock positions and 3 axle positions.  It's steel box-section.  I've seen photos of  RC swingarms that look similar, so it could be one of his.
Six-Minneapolis.
Offline Dougy Dougy Dune Buggy
  • Wrenchin Mofo
« Reply #10 on: September 24, 2007, 11:36:17 AM »
Lofathd,
I currently have a 19" Front AND 19 Rear on my 500/550. They are Borrani wheels that the previous owner decided to run, he's run them no problem for like 6000 miles!
Later,
DWYJ
I'm going to Cafe it
ONE DAY
ha ha
Offline bigsherm
Hey DWYJ, how about a pic of your bike with the 19"-ers?
« Reply #11 on: December 17, 2007, 11:29:44 PM »
Sporty 19" rear tires are hard to find, aren't they?  What size and brand are you running?
-Sherm
