Author Topic: aluminium caliper piston question (2)  (Read 1071 times)
Offline freggy
« on: September 21, 2007, 06:56:13 AM »
does anyone know if there will be a heating problem of an aluminum caliper piston compared to a steel one?
I know expansion of aluminium is not the same as steel.
I don't think it will be a problem as the caliper housing is aluminium also but just to make sure...
Thanks
Offline bert96
  • past ride
Re: aluminium caliper piston question (2)
« Reply #1 on: September 21, 2007, 07:21:19 AM »
 Why would you use aluminum piston?
There are a guys on ebay who sell stainless pistons,IMHO i think they would be much more better...just my 02 cents  ;)
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
« Reply #2 on: September 21, 2007, 09:36:26 AM »
I agree, the expansion might be a problem when it gets hot...like under heavy breaking.  Aluminum would also transfer heat faster into the brake fluid, too!  You going to change to hi temp brake fluid, too?
Have you considered the phenolic ones available from Kevin Hunter on eBay?
« Reply #3 on: September 22, 2007, 01:04:19 AM »
Alloy piston in alloy bore not a good idea cos of corrosion. Dissimilar metals do better
Offline ieism
« Reply #4 on: September 22, 2007, 06:49:32 AM »
I have an aluminium piston in my 550 frontbrake, it works great. I drove halfway across Europe with it (mountain passes and everything) without a problem, so I have no problem recommending these. Overheating was not an issue.
I was sceptical at first too, but the guy I bought it from is a SOHC specialist and has sold a lot of them for years with no problem.
---cb550---
