Author Topic: Air Cleaner Box  (Read 1238 times)
jgidds
Air Cleaner Box
« on: September 21, 2007, 02:50:05 PM »
Is there any place to find an air box assy. For '76 CB550?  Seems to be a tough find.  I have four little cheap A$$ pods and it runs like poop.  Won't idle when warm and runs really rich.  I have some sort of after market pipes.  I would like to go back to stock pipes and stock air cleaner assy.  Any suggestions as to where I can find the air cleaner box assy.?
Offline OldSchool_IsCool
  • Really feeling like an
Re: Air Cleaner Box
« Reply #1 on: September 21, 2007, 03:05:33 PM »
You're right! they are a tough find.  Almost as hard to find as stock pipes!  :o
You can check M/C junk yards most likely.  You could also re-jet your carbs to match your pod/pipe set-up as is.
Oh, and welcome to the Forum!
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
Re: Air Cleaner Box
« Reply #2 on: September 21, 2007, 03:13:48 PM »
Open airfilters and aftermarket pipes typically lean out the fuel condition. If your's is rich then maybe it just needs a little tuning.
that would be easier than finding the stock parts. ;)
here's the carb section of the FAQ if you have'nt found it yet:
http://www.sohc4.us/forums/index.php?topic=5410.0
Welcome also, Matt.
Gallery at:
rlarkin70
Re: Air Cleaner Box
« Reply #3 on: September 21, 2007, 05:07:47 PM »
Has anyone ever fabricated their own airbox for a CB550? Using sheet metal, silver soldering the seams, using some type of headers. This way it could be customized to use a commonly found air filter element. Just curious!
I am looking for an airbox for my 76 CB550 too. They seem hard to find and expensive. I thought maybe it wouldn't be a big deal to build one, and then if necessary, re-jet and tune the carbs.
I have the pods, and they really suck.
-Ron
Re: Air Cleaner Box
« Reply #4 on: September 22, 2007, 01:01:55 AM »
As long as its not a K3 model any 500/550 will fit the only difference on a 500 is that the big breather from the top of the engine does not connect to the bottom of the filter box.
ALSO you can now get just the box to carb connector rubbers seperate from Dave Silver (£18 per set) as a pattern part as these were never available from Honda
Offline edbikerii
    • Gallery
Re: Air Cleaner Box
« Reply #5 on: September 22, 2007, 05:02:47 AM »
If you are running rich with pods, then you've got other carb problems going on that the airbox won't fix anyway.  Pods lean out the mixture over the stock airbox.
Pods work great if you take the time to re-jet.  I use 105 mains on my '77 CB550 and they work incredibly well.  I'll never go back to the stock airbox.
77 and 78 models have "lean burn" carbs, so jetting on your '76 may differ slightly.
SOHC4 #289
1977 CB550K - SOLD
1997 YAMAHA XJ600S - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
