Author Topic: fork bolt stuck, please help  (Read 6421 times)
Offline motomotard
    • GoGo Garage
« on: September 25, 2007, 04:17:14 PM »
so im replacing the seals in my forks on my 73 cb750.
got one apart no problem. the second one is driving me crazy. the hex bolt on the very bottom of the fork will not come loose. wont budge, tried wd40 and all manner of banging on the damn thing and it wont move. the bolt is starting to strip.
any suggestions very appreciated.
Offline miles nowhere
  • motorbikeist
    • Miles Hunsberger Tattoos
Re: fork bolt stuck, please help
« Reply #1 on: September 25, 2007, 04:21:14 PM »
impact driver.
78 cb 750k8, 78 cb 750F3, 78 cb 750F3, 74 cb 750k4
Offline greenjeans
  • 1972 CB750K2
« Reply #2 on: September 25, 2007, 04:26:25 PM »
Acetone & ATF fluid.  let it soak...  heat it with a heat gun.  I've also used PB blaster and a heat gun followed by some tapping....
Have you taken the big bolt off the top of the fork yet ?    You can use a wooden plunger handle and a bar clamp to put some force on the inside.
Offline tomkimberly
« Reply #3 on: September 25, 2007, 04:59:47 PM »
Remove the cap, remove the spring and everything else that falls out of the tube, borrow a broom handle from your wife, stick broom handle inside fork tube and set assembly on the ground broom handle down, now loosen the allen bolt.
Tom
Offline Patrick
« Reply #4 on: September 25, 2007, 05:19:28 PM »
Leave the spring in and the top cap on. Get a tie down. Compress the fork leg as much as you can with the tie down, putting pressure on the lower socket head bolt. Now hit it with an impact driver. That's how I got the fork bolts out of my 1969 DT1 and those were so rusty I had to scrape off grunge to find the bolt head.
Good luck.
Patrick
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
« Reply #5 on: September 25, 2007, 05:34:08 PM »
Hit it with some penetrating oil, let it sit overnight and use a broom handle. It will come right out. Every old time wrench I ever net used the broom handle.
Offline motomotard
    • GoGo Garage
« Reply #6 on: September 25, 2007, 06:25:35 PM »
thanks for the suggestions, my buddy has an impact wrench, he suggested that so ill do that tomorrow. if it dosent work ill do the broom handle thing.
Offline motomotard
    • GoGo Garage
« Reply #7 on: September 25, 2007, 06:27:45 PM »
and yeah ive already pulled the big bolt and the spring.
« Reply #8 on: September 26, 2007, 05:35:12 PM »
Save your time. The impact wrench will do nothing more than spin the inner tube. Bring he broom handle with you and use the impact wrench.
Offline motomotard
    • GoGo Garage
« Reply #9 on: September 26, 2007, 06:02:29 PM »
fixed.
i let it soak in wd40 over night and hit it with the impact wrench today. it came loose right away, didnt have a broom stick w/ me so it took a little jigglin to get it out, but it worked.
thanks guys.
