Author Topic: Please help ID these con rods...  (Read 1062 times)
Offline Patrick
« on: September 25, 2007, 05:31:25 PM »
MY project K0 came with a spare set of connecting rods. They look like the rods in the engine, but the markings are different. On the connecting bracket they have the markings "52" and then on the other side what looks like a "J." On the shaft of the rods they are marked "S29F." For all I know these are the originals and the con rods in the engine are replacements. Can anyone provide any info? I don't have another set of K0 rods to compare to.
Thanks,
Patrick
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline Soos
Re: Please help ID these con rods...
« Reply #1 on: September 25, 2007, 06:13:38 PM »
Are the rods steel, or aluminum?
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
Offline Patrick
« Reply #2 on: September 25, 2007, 06:41:58 PM »
It looks like they're steel. Here's a picture. Bear in mind that I haven't cleaned these up yet, so they are not yet pretty. They look solid, though and the bearings with them seem to be in good condition.
The con rods in the bike don't seem bad, at first glance. But I figured as long as I have it apart I might as well use the best available.
http://i130.photobucket.com/albums/p247/wordguy11111/HPIM1836.jpg
Patrick
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline scondon
  • Mmmm......tasty bugs
« Reply #3 on: September 25, 2007, 06:54:46 PM »
 Those look all the world like stock rods to me.
Offline sparty
  • I just play one on TV
    • Gallery
« Reply #4 on: September 25, 2007, 06:54:57 PM »
Patrick
Patrick,
If you are considering using better con rods you need rods with much stronger bolts.  The ones in your pic are not any better than stock con rods.
Sparty
1972 CB750 K2 Cafe' Style
Offline Patrick
« Reply #5 on: September 25, 2007, 07:02:54 PM »
I probably need a closer look at the rods in the bike. I've split the cases, but I haven't pull the rods or the crank yet. The bike had an 810 big bore kit installed, so he might have upgraded the rods at the same time. That would be pretty cool.
He never got it to run.
Patrick
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline sparty
    • Gallery
« Reply #6 on: September 25, 2007, 07:11:56 PM »
Patrick
That would be a bonus, I'll keep my fingers crossed for you.  Pics when you get it apart.
