Author Topic: Headlight help!  (Read 1284 times)
Offline Odge
Headlight help!
« on: September 25, 2007, 05:39:46 PM »
I bought a 1975 750k and have been sorting out the problems. One that is stumping me is the headlight. It works, and is really bright, but doesn't have a low beam. The dimmer switch does nothing, and the hi beam indicator never lights. I have to use manual low beam (pulling my light up and down) and this gets a little hairy on the move. There is a lot of funky "custom wiring" that I have inherited with the bike, but am not sure if that is the problem. I did poke around in the rats nest in the headlight shell and it seems like all the direct connections to the headlight are ok. Any ideas?
Offline Johnie
Re: Headlight help!
« Reply #1 on: September 25, 2007, 07:44:34 PM »
Since you inherited a lot of "funky" wiring with the bike, I would suggest getting a wiring diagram and follow it.  Hopefully the colored wire is still the same so you can follow the wiring diagram.  A test light would be of help too.  Good luck with the project.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline motomotard
    • GoGo Garage
Re: Headlight help!
« Reply #2 on: September 25, 2007, 10:15:05 PM »
i had the same problem w/ my bike when i got it. PO had done a bunch of electrical tape wire splicing and other goofy stuff. a clymer manual w/ wiring diagram will be your best friend. as long as the wire colors are the same it shouldnt be hard to fix.
Offline johnny
Re: Headlight help!
« Reply #3 on: September 25, 2007, 11:26:47 PM »
You can probably find what you need here:
http://oldmanhonda.com/MC/WiringDiagrams/MCwiring.php
1976 CB550K
1974 CB350F http://forums.sohc4.net/index.php?topic=81781.0
1974 CB550K
1972 CB350 Twin
1965 Lambretta
196(?) Honda S90
1975 Ford Bronco
Offline Odge
Re: Headlight help!
« Reply #4 on: September 26, 2007, 01:21:53 PM »
Thanks for the help. I think I need to suck it up and pay for a clymer manual and start investigating. Now I have to repeat the mantra- "electricity is my friend..."
Re: Headlight help!
« Reply #5 on: September 26, 2007, 01:24:59 PM »
Better choice would be the Honda Shop Manual.  Instead of selected passages/data copied by clymer.
