Author Topic: Total weight and weight distribution of cb750  (Read 1363 times)
Offline 750essess
  • Orleans Cycle Repair & Resto
« on: September 26, 2007, 06:59:46 AM »
Been trying to figure out the slight wobble I have at high speed. Weighed the bike and got 460 lbs total with 240 at back wheel and 220 on front. Anyone now what the stock weight distribution is? I am thinking being light on the front is causing my problem.
Orleans Cycle Repair and Restoration
76CB750F
69Z50
XR650L
Offline 750essess
Re: Total weight and weight distribution of cb750
« Reply #1 on: September 26, 2007, 07:24:34 AM »
Well, what do you know. Its in the manual. Total weight for a k model is 517.3 lbs and distribution is 271 L and 209.5 R . I assume the L is the back and the R is the front.
76CB750F
69Z50
XR650L
Offline Irishguy
« Reply #2 on: September 26, 2007, 08:48:21 AM »
I would think it would be the left and the right of the bike.  Measured from the centerline.  You could test my theory out by standing the bike straight up using a plumb bob and then letting the bike fall over.  Which ever side it fell over on would be the heavy side.   ;D
Offline 750essess
« Reply #3 on: September 26, 2007, 09:06:47 AM »
That might bend something...how bout I let it fall on me or better an unsuspecting friend and see which side hurts the most  ;D
76CB750F
69Z50
XR650L
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #4 on: September 26, 2007, 09:32:35 AM »
Rims out of true, worn steering bearings, low tire pressure, loose brace?
I have a slightly noticeable wobble at 110mph+ :/ course, my forks are slightly screwed.
No.
Offline 750essess
« Reply #5 on: September 26, 2007, 10:10:44 AM »
Rims are new, checked for tightness. New tapered steering bearings, double checked. Tire pressure is good. Has a cbr600 front fork on it. It runs true in a straight line just does it mid corner.
76CB750F
69Z50
XR650L
Offline tsflstb
« Reply #6 on: September 26, 2007, 10:32:26 AM »
These bikes are a little more tail-heavy than anything modern.  My 400 still has about 15 more lbs. on the rear than the front, and I've made a lot of effort to lighten it up and shift the weight forward.
I would think 220 lbs. on that CBR fork would be plenty to keep it planted, but maybe it needs to be re-valved for it's current application.  Maybe the rake of the CB's frame vs. the CBR's makes a difference?
Offline 750essess
« Reply #7 on: September 26, 2007, 11:37:02 AM »
Its possible. The rake has come out about the same as the CB since I lowered the rear a little, the trail is much less though. What I think is strange as straight line stability is great. There are few others with a similar conversion, but they aren't finished yet or I haven't seen anything about how they handle. As far as I know I'm the only one that used wire wheels with this setup, could be causing a problem too.
76CB750F
69Z50
XR650L
