Author Topic: New MC - no pressure  (Read 945 times)
Offline firecracker
  • At being Shameless, I'm an
« on: September 26, 2007, 07:15:21 AM »
Installed a new MC, but can't get any pressure.
I'm using a speed bleeder, and I can get some brake fluid out, but not much, and only when I keep the lever squeezed (almost like gravity is doing it more than the lever).
Repeated sqeezing doesn't force more out.
Any suggestions?
Life is like a game of cards.  The hand you are dealt represents determinism.  The way you play it is free will.
  -  Jawaharal Nehru
Offline tsflstb
Re: New MC - no pressure
« Reply #1 on: September 26, 2007, 07:43:16 AM »
I had the same problem when I installed a brand new master cylinder and speedbleeder at the same time.  I almost sent it back thinking it must have a bad seal.
I ended up using my old stock bleeder until I felt some slight pressure at the handle, then (quickly without losing too much fluid) re-installed the speed bleeder.  The manual bleeder worked better to get the system primed, after that the speedbleeder worked great.  I think the little check valve in the speedbleeder needs some differential pressure across it to start working.
Offline firecracker
« Reply #2 on: September 26, 2007, 07:55:58 AM »
I'll try that tonight.
Thanks!
  -  Jawaharal Nehru
