Author Topic: Will a dohc fender fit on a sohc?  (Read 1749 times)
newcbguy
« on: September 28, 2007, 06:52:27 AM »
As I am starting to peice together my project bike a '71cb750k1, I am wondering if I can fit a dohc front fender ('80 model or so)? I like the lower profile look of these fenders with out the fender braces. Has anyone done this?
« Last Edit: September 28, 2007, 06:54:34 AM by newcbguy »
Offline Geeto67
  • A grumpy
Re: Will a dohc fender fit on a sohc?
« Reply #1 on: September 28, 2007, 07:12:43 AM »
I happen to like the 79-80 cb750F front fender also as it hugs the front wheel nice and close. I had one I bolted to a SOHC fender mount. The Fender is plastic so it will need some kind of brace underneath. Currently it is in my attic and I didn't have much road time on it before I decided to ditch it all together. I never tried to bolt the fender to the stock forks, but from what I can see the front forks on my brother's 79 DOHC F and my 78 DOHC F are pretty similar.
Stay away from the later 81-82 front fenders, that little spoiler on the front fender  looks gay on these older bikes.
Maintenance Matters Most
newcbguy
« Reply #2 on: September 28, 2007, 09:47:46 AM »
ok from what I can see on evilbay it looks as though the fender mount hole locations are different. I wonder if the width is about the same so you could just drill new mount holes?
Offline mick750F
« Reply #3 on: September 29, 2007, 06:41:42 AM »
   I tried this a couple of years ago and found out that the fender mounts are different. I don't remember if the holes in the fork lowers are located differently or if the fender mount/brace was a different length...or both. The fender would hit the tire before the holes would line up. I decided that the best way to mount a dohc fender on sohc forks was to attach the dohc fender to a sohc fork brace. I haven't done it yet...just another of those things I'll get around to someday.
Mike
Glosta, MA
newcbguy
« Reply #4 on: September 29, 2007, 06:54:11 AM »
I wonder if there is enough material on the dohc fender mount to make new holes to lign up with the sohc forks?
Offline mick750F
« Reply #5 on: September 29, 2007, 07:58:00 AM »
 Nope. The dohc fender rests on the tire before the holes are close.
Mike
Glosta, MA
