Author Topic: HAS ANYONE MADE A TEMPORARY GAS SOURCE?  (Read 2159 times)
Offline dramsell
« on: September 28, 2007, 12:16:58 pm »
I am attempting to revive an old neglected 78 Cb 750F that has a gunked up tank. I want to make a temp gas source to see if the bike will start and adjust carbs.  Any ideas?
Dave R
Offline Hondell
  • Just an easy 1000 Hr. resto
Re: HAS ANYONE MADE A TEMPORARY GAS SOURCE?
« Reply #1 on: September 28, 2007, 12:19:30 pm »
Yep, a square plastic tank from a lawn mower or roto tiller suspended from the handlebars is just the ticket... cheap too
1972 Cb750 resto- 1972 Cb750 stoplight racer- 1972 Cb750 vintage touring - 1979 CBX- 1982 Kaw GPZ- 1968 Honda SS125A
Offline Geeto67
  • A grumpy
« Reply #2 on: September 28, 2007, 12:25:12 pm »
I used an old motocrosser oil tank with a fuel tap epoxied on and hung it from an IV stand I found in the trash (I live next to a hospital). Works great espically since the IV stand is on wheels.
You have to elevate the tank to let the gravity feed work it's magic in feeding the carbs. An old coat rack like you find in the trash or in thrift stores for $5 is good for this. In truth you only need a couple of pints of gas to test any carb bank, so a 3 qt tank like those used on 2 stroke bikes for the oil works well. If you can't find a fuel tap to screw into the tank, you can use a length of hose and a shutoff valve like the ones they use for natural gas.
Maintenance Matters Most
Offline Tower
  • Only at conception could I have been called a
  • My personal time machine: 1973 CB750K3
« Reply #3 on: September 28, 2007, 01:01:25 pm »
In the spirit of DIY, here is the manometer I constructed with a temp gas tank attached (see attached picture).  It was more expensive to construct that I had expected.
4 gauges (Canadian tire - $30/each)
2x4 x 6' (old stock)
Square metal base (found in ravine behind my house)
100 lb Castor wheels w/brakes x 4 (Home Depot - $5 each)
1/2 x 20" Copper pipe (old stock)
Rubber caps  x 2 (Canadian Tire - $2)
Air hoses and air valves (aquarium store - $4 + $1 each)
Brass fuel couplers -splitter, 2 barbs, valve (Canadian tire - $30)
Fuel line  2 1/2' (Canadian Tire ($10)
Washers and bolts (old stock)
Tank - cookie tin, seams filled with solder (old stock)
Paint - Black and Silver (Canadian Tire - $7)
It was a toss up between using the old cookie tin and an old turpentine can.  Can didn't need sealing, but cookie tin had wider opening for filling with gasoline.
« Last Edit: September 28, 2007, 02:59:46 pm by Tower »
Offline hopterfixer
    • My flickr Gallery->
« Reply #4 on: September 28, 2007, 01:14:38 pm »
A transmission funnel with a plastic hose barb fitting in the end, and a Y to go to each hose on the carbs.  The funnel even has a little hole to tie it to a mirror or hang it from the ceiling.
Offline angeldeville
  • You meet the nicest people on a Honda!
« Reply #5 on: September 28, 2007, 01:54:32 pm »
IV stand and Glass IV bottle here....
76' cb750f custom
69' cb750 sandcast
69' CT90
Amen Saviour 750 Chopper frame
and enough parts to build about 6-7 more bikes
Offline Bodain
  • I love the smell of fresh asphalt in the morning!
« Reply #6 on: September 28, 2007, 02:20:43 pm »
I use a funnel.... I mount a funnel ( plastic) on the handlebars. The funnel feeds the gas hose to the carbs. I add gas as needed.  Low cost and effective.
2009 Suzuki TU250
2014 Honda Grom
1984 Kawasaki GPZ 750
2005 Yamaha Zuma 50
1974 Honda CB 750
1979 Kawasaki Z750 Twin
Offline Bikebuff
« Reply #7 on: September 28, 2007, 02:30:36 pm »
Sure, I just eat cereal with a lot of fiber in the morning (Kashi Go Lean or Fiber One with raisins), and in the evening I eat beans.  Plenty 'o gas to start my 750 (and peel paint).
Seriously, I bought an auxilary tank from Z1 Enterprises and a T-line from Home Depot (I've got a dual outlet petcock for my '70 750).  Cleveland's offered to let me borrow his synchronizer (when I finally am ready to synch the carbs).
Prost!
http://www.ladyofthecake.com/mel/saddles/sounds/fart2.wav
Long Live Blazing Saddles!
Offline Donzon
  • CB750K4
« Reply #8 on: September 28, 2007, 04:59:24 pm »
Old windshield washer fluid reservoir.
Don
Offline feliz
« Reply #9 on: September 28, 2007, 08:50:20 pm »
I just sit the tank from the bike on a stepladder standing beside the bike. Of course I add longer hoses. I also hang my Emgo gauge set on the ladder as well.
feliz
Current bikes:
05 Ural Patrol
CB750K1, K3, K4
08 Aprilia Shiver
Offline CrisPDuk
  • Christ on a bike! Me, an
« Reply #10 on: September 28, 2007, 11:14:37 pm »
I used to do it that way feliz, but using a garden table rather than a stepladder, until one day I accidentally stepped back into the table and sent my shiny new paint job crashing to the ground :(
1978 CB550 K3
1985 H100S
Offline Gordon
  • 750K1, 550K2
« Reply #11 on: September 28, 2007, 11:34:08 pm »
Same here, but I think mine was on an old barstool, and it was an old, cracked paint job, so I got off fairly easy.  Some lessons can only be learned the hard way. :'( :'(
Offline spitfire
« Reply #12 on: September 29, 2007, 02:10:49 am »
I use a wheely bin and longer fuel lines, but I do tie the tank to the wheely bin.
Cheers
Den
Wirral UK
1976 CB750F1 bought new in 76
1977 CB750F2: Restoration started
1964 BSA A65R: Waiting restoration
My gallery is here: http://www.sohc4.us/gallery/v/members/personal/spitfire/?g2_navId=x5a30f7b6
johnny-from-bel
« Reply #13 on: September 29, 2007, 02:58:09 am »
plastic botlle.
Offline my78k
« Reply #14 on: September 29, 2007, 07:07:21 am »
old plastic lawn mower tank
Offline RatBikeRandy
  • Yes I Can
« Reply #15 on: September 29, 2007, 10:23:00 am »
Nearly free.  2 liter Coke bottle. Drill progressively larger hole in center of cap until clear fuel line will just push through.  Trust me, I have never had a leak.  Put gas in the bottle, screw on the cap hang upside down from stepladder nearby.  I usually cut 2 small slits for a long zip tie to suspend the bottle - this also acts as air vent.
Offline feliz
« Reply #16 on: September 29, 2007, 12:31:05 pm »
Oooops, maybe I'll rethink my method, I'd hate to do that to my nice original 37 year old paint.
feliz
Current bikes:
05 Ural Patrol
CB750K1, K3, K4
08 Aprilia Shiver
Offline kghost
« Reply #17 on: September 29, 2007, 09:09:40 pm »
Marvel Mystery oil can...and an old petcock.
Stranger in a strange land
Offline medic09
« Reply #18 on: September 29, 2007, 10:21:05 pm »
Hey Angel,
WHERE did you find a glass IV bottle?  Antique store, or empty nitro bottle?
Mordechai
'78 CB750K
'07 aprilia Caponord
Santa Fe, NM
Offline GroovieGhoulie
  • I have to return some videotapes.
« Reply #19 on: September 30, 2007, 12:27:13 am »
Hey Angel,
+2
I am trying to find that very hardware, since that sounds like an ideal set-up.
I have a IV stand, but no bags or bottles.  Will probably rig up a small plastic container with some fuel line leading to a tip.
« Reply #20 on: September 30, 2007, 02:43:04 pm »
how many do you guys want?
76' cb750f custom
69' cb750 sandcast
69' CT90
