Author Topic: Engine paint  (Read 1929 times)
Offline Mike the bike
Engine paint
« on: September 29, 2007, 06:29:42 pm »
I had the engine parts vapour blasted prior to painting and sprayed them with etch primer, followed by VHT silver spray paint.  I'm not happy with the finish because
a) the silver paint comes off
b) it just doesn't look authentic - it looks like a spray job
Is powder coating the engine a good idea Y/N? or will the silver spray look more original with a few coats of clear laquer?
If you can't see light at the end of the tunnel, go down the tunnel and light the chuffing thing yourself
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
Re: Engine paint
« Reply #1 on: September 29, 2007, 07:41:16 pm »
Do a search on the forum for "engine paint" and you will find hours of ideas....... ;)
newcbguy
Re: Engine paint
« Reply #2 on: September 29, 2007, 08:30:50 pm »
did you use the vht engine paint? I used the dupli-color 500deg. engine paint on mine after etch prime. it has a ceramic content that helps it stick to the engine after it is baked on.
Offline mazingerzeca
Re: Engine paint
« Reply #3 on: September 30, 2007, 02:10:09 am »
Which kind or brand of etching primer did you use? Was it also a hi-temp etching primer? Which brand?
Offline spitfire
Re: Engine paint
« Reply #4 on: September 30, 2007, 07:53:55 am »
Hi Mike,
          Used VHT on mine, no primer just very clean engine parts, seems good so far, everything apart from the crankcases was sprayed, allowed to dry ovenight and then cured in the oven.
Cheers
Den
This is the paint I used
« Last Edit: September 30, 2007, 07:59:19 am by spitfire »
Wirral UK
1976 CB750F1 bought new in 76
1977 CB750F2: Restoration started
1964 BSA A65R: Waiting restoration
My gallery is here: http://www.sohc4.us/gallery/v/members/personal/spitfire/?g2_navId=x5a30f7b6
Offline EBCB
    • Earache Motorsports
Re: Engine paint
« Reply #5 on: September 30, 2007, 08:24:48 am »
Spitfire - I'm guessin' you're not married, right? ;D
Looks good! I need to get going on my motor paint this winter.
Offline Bob Wessner
  • "Carbs Suck!"
Re: Engine paint
« Reply #6 on: September 30, 2007, 09:06:49 am »
It doesn't look like he bakes much either. Cleanest oven I've ever seen. ;D Also second the good work, looks great.
