Author Topic: Rear shock mount ???  (Read 1060 times)
Jbird
« on: October 02, 2007, 07:27:13 PM »
 I have two rear lowering kit shock mounts, they move the lower shock mount point to just behind the the axle. The shock angle changes quite a bit. The bike's not quite ready for the road yet, I bolted them on just to see how much it lowered the rear. I like having the seat lower. Are these things a good idea? Will the bike handle better or worser?
All I need are front brake hoses and an alternator gasket and the 76 K6 will he ready for a shake down cruise after ten years in carport storage.   TIA   Jbird 8)
Offline Gordon
  • 750K1, 550K2
Re: Rear shock mount ???
« Reply #1 on: October 02, 2007, 07:34:46 PM »
The only thing you can be sure of with the lowering blocks is that it will handle "different".  Better or worse is the rider's own opinion.  I have them on my 550 and they work fine, but I pretty much only take it on short, in-town trips.  I tried them on my 750, and didn't like the change in handling.  They decreased the cornering clearance and suspension travel too much.
Offline medic09
« Reply #2 on: October 02, 2007, 08:37:21 PM »
If you want the bike *lower*, as opposed to wanting a particular 'look', you can do several things.  Search for the threads, 'cause we've discussed it a bit.
I have shorter shocks, which are frequently available on eBay, or elsewhere.  I also have a cut-down seat.  For me that works well.
Mordechai
'78 CB750K
'07 aprilia Caponord
Santa Fe, NM
Offline 736cc
« Reply #3 on: October 03, 2007, 04:17:54 AM »
If you lower your ride, say goodbye to hi-speed cornering. Hard things will drag when you don't want them to.
Offline bert96
  • past ride
« Reply #4 on: October 03, 2007, 05:04:25 AM »
Maybe  i'm wrong but i think you'll need a shorter side stand.
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
