Author Topic: Sparty's bike comes to life... but... (Oil leak fixed) 10/8  (Read 19142 times)
Offline sparty
  • I just play one on TV
    • Gallery
« on: October 03, 2007, 07:38:33 PM »
Success at last!  The engine came alive tonight after many months of work.  I ran the engine for a few minutes to get the oil circulating and check for potential problems.  It took a while to get the oil light to go out, but once it did, I was relieved. However, I do have an oil leak from one of the bottom end studs (see pics below) so I have to tackle that problem.  I called Mike, the engine builder, and he suggested that I take the nut off and seal the rubber washer with some Honda HT gasket sealer.  Any other suggestions are welcome.
The engine got pretty warm, but my oil cooler stayed cool.  I was worried that it wasn’t flowing through the cooler so I unhooked the oil lines and looked for oil, it dripped out, so I assume oil was circulating through the lines.  The engine took almost 6 quarts of oil, I was a bit surprised, but the oil filter is large and with the cooler and extra lines, they could easily take a quart alone.  I looked in the oil tank and saw a purpleish oil, so the assembly lube has begun to come off.
The bike is idling a bit high at the moment, around 2000 RPM.  I need to adjust the idle screw, but it is difficult to reach.  The CR carbs worked flawlessly.  My exhaust note is LOUD even at idle.  The comp baffle sounds great.  Earplugs will be required.
« Last Edit: October 07, 2007, 06:59:40 PM by sparty »
1972 CB750 K2 Cafe' Style
Offline sparty
    • Gallery
Re: Sparty's bike comes to life... but...
« Reply #1 on: October 03, 2007, 07:42:32 PM »
pic
Offline sparty
    • Gallery
« Reply #2 on: October 03, 2007, 07:44:39 PM »
another
Offline keiths
« Reply #3 on: October 03, 2007, 07:58:27 PM »
Congratulations! I'm sure you'll work out the oil leak.
Offline scondon
  • Mmmm......tasty bugs
« Reply #4 on: October 03, 2007, 08:44:21 PM »
 Awesome, Sparty. Don't let that little dribble stop ya from taking a spin around the block ;)
   I forgot that you had those wicked crank studs installed. I'm not familiar with them but Mike's advice sounds right to me. I don't believe you have anything to worry about if you want to liberally apply sealant to that area. Hopefully Mike remembers what he torqued the bolts to and you have a good torque wrench handy.
  6 quarts is a lot of oil, even with a cooler. I've got a small Deraile cooler and it takes about 1/4 quart more oil than the 3.7 spec'd for my bike. After it's run for a bit you may want to recheck the level. My level sank low and then rose back up when I started for the first time. It may be that your bike takes 6 quarts with all the stuff you've added, but if your crank is submerged in oil it may be contributing to the leak.
  The Motion Pro remote fuel tank is a cheap addition to the garage  if you don't already have one, or similar. Makes synching the carbs, tuning, and getting that idle set a breeze.
  Glad to hear the day has finally come and that only the usual, minor stuff is in your report ;D
« Last Edit: October 03, 2007, 08:45:58 PM by scondon »
« Reply #5 on: October 03, 2007, 09:00:14 PM »
Yea Sparty !!
Take 2 quarts out! Run it then top it off if you need to. 6 is way too much.
« Reply #6 on: October 03, 2007, 09:05:36 PM »
Well done Art, time to rock and roll ;D ;D ;D ;D ;D ;D
Sam. ;)
« Reply #7 on: October 03, 2007, 09:58:53 PM »
You could also use some plumbers ptfe tape on the threads in case its coming down there
Offline mrbreeze
  • Not your average
« Reply #8 on: October 03, 2007, 10:22:18 PM »
Happy trails Sparty!!!!!!!
MEMBER # 257
Offline Soos
« Reply #9 on: October 04, 2007, 04:23:47 AM »
AWESOME....
So whens the dyno test???? :o :o :o
If it rides half as good as it looks, it should be awesome!
Hey what about a sound byte or two so the rest of us drooling on our keyboards can feel even more envious?
 ;D ;D
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
Offline sparty
    • Gallery
« Reply #10 on: October 04, 2007, 04:58:51 AM »
Yea Sparty !!
Ooops.  I misread the gallon container of oil.  I have more like 5 quarts in.  It normally calls for 4.2 quarts.
Offline KB02
« Reply #11 on: October 04, 2007, 05:24:07 AM »
Yea Sparty !!
That sounds a bit better.   :)
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline RRRToolSolutions
  • I love old Japanese bikes!
« Reply #12 on: October 04, 2007, 05:33:55 AM »
Art - be very careful filling it. I know someone that was burnt badly when his oil tank over-flowed as the oil was pumped up and heat. It's a dry sump of course and the tank will rise as the engine is run.
I turned my handle switch to "off" and turned my engine over in short burst until I had oil pressure before starting. Just me, but I did not want a dry start (I offered you a gauge). Those case studes should be around 20 lbs. The stock ones went to 14 - those should go to 18-20 easy.
I've got the same 1.5 baffle and mine is all music...no worse than most slip-ons added to the sportbikes. You're going to enjoy the sound of 10,000! Sweet.
Kaws, Hondas, Yamahas, and Suzukis - especially Kaws
« Reply #13 on: October 04, 2007, 05:46:39 PM »
Gordon....yes, those studs 20 to 22lbs. I heard the engine over the phone at idle and  couple of soft revs. That thing will rock. I know...I built it and I stand behind it.
« Reply #14 on: October 04, 2007, 05:56:42 PM »
Yeah, and get covered in bits of smoking rubber  ::) ::) ::) ::) ;D ;D ;D ;D ;D ;D ;D
Sam. ;)
Offline Leino
  • Not much of an
  • in drag racing since 2005
« Reply #15 on: October 04, 2007, 06:09:23 PM »
Sam. ;)
That's the way to go!  ;D
« Reply #16 on: October 04, 2007, 06:22:05 PM »
You'd think a guy with his intelligence would stand to one side ;D ;D ;D ;D ;D ;D ;D ;D
Leino, I remember it happening to the owner of Santa Pod in the early days. He brought E J Potter ( the Michigan madman) over with his V8 bike. The guy had just had the strip resurfaced and when EJ rolled it off the line he got covered in rubber.
He thought it was his new surface breaking up ;D ;D ;D ;D ;D ;D ;D
Sam ;)
Offline Leino
  • Not much of an
« Reply #17 on: October 04, 2007, 06:39:30 PM »
Yeah, or at least wear goggles.  ;D
Offline sparty
    • Gallery
« Reply #18 on: October 04, 2007, 06:40:21 PM »
Guys,
After a cleaning with BrakeClean I sealed the leak with some Hondabond HT around the upper part of the stud and washer.  Then I coated the threads and inside of the nut with PTFE.  I TQ'ed the nut to 21 lbs. in between the 20 to 22 range.  At the moment there is no oil leak.  I didn't start the bike today, I want it to cure for 24 hours.  The PTFE never dries "hard".  I put a light coat of PTFE around the base of the nut and washer for extra measure.  Over the winter, I'll pull the exhaust and do that to all of the studs.  I checked the oil. 4.7 quarts were filled.  It calls for 4.2, but with the cooler, large filter and lines, plus some spillage, the 4.7 seems about right.
You guys need to get yourself a Dyna 2000 ignition.  Timing it is a breeze!
I have video, but I couldn't get it to post on YouTube.  Not sure why.  I'll try again this weekend.
Sparty
Offline sparty
    • Gallery
« Reply #19 on: October 04, 2007, 06:50:12 PM »
Oh, I forgot... when the bike was running I could hear the cam chain, I am not 100% sure how loud it should be with the new build.  It wasn't a rattle, more like a spinning chatter at idle.  I goosed the throttle a bit, just to 3000 or so RPM, the revs come up quick with the lightened and balanced crank, Falicon rods, balanced rotor and Megacycle 125-75 cam.
I'll be waking up the neighborhood on Saturday morning to the sweet sound of the Kerker ;D
Sparty
« Reply #20 on: October 04, 2007, 06:53:01 PM »
 ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
« Reply #21 on: October 05, 2007, 04:30:43 AM »
Sounds good Art, but the only concern I have is the oil just "dripping" out of the cooler lines, the pressure should be pretty high there mate as all the adapter does is redirect the oil flow, so if it's not warming up your cooler at stand-still, just check to make sure you haven't kinked your lines, and that your oil pump is working as it should. If you've got an oil pressure problem it'll destroy all that beautiful work on your first run! Cheers, Terry. :)
« Reply #22 on: October 05, 2007, 04:37:15 AM »
Art, I have a oil pressure gauge/tool for shop use I will loan you. You just remove the plug at the base of #4 cylinder and screw this in - it will tell you exactly what pressures you have in there. Mine starts at 60~70 and when the oil thins - it hangs around 50~60. The starter will generate 30 lbs, so it comes up quick.
Let me know.
Gordon
Offline sparty
    • Gallery
« Reply #23 on: October 05, 2007, 05:11:27 AM »
You are scaring me Terry.   The oil was dripping out when the bike was off.  The lines are not kinked.  Now I am worried.  Damn.
Offline sparty
    • Gallery
« Reply #24 on: October 05, 2007, 05:14:34 AM »
Let me know.
Gordon
Thanks, I could use that.  Terry has me worried that I might have a problem.  When can you send it?
