Author Topic: Sparty's bike comes to life... but... (Oil leak fixed) 10/8  (Read 15933 times)
Re: Sparty's bike comes to life... but...
« Reply #50 on: October 07, 2007, 10:01:08 AM »
I’ll be sure to put the video camera close to the engine so that you can here the mechanical noise.  I love the sound, but it is a bit worrisome after all the work.
Don't worry about the noise, ours was the same when we got rid of the megaphones. ::) ::) ::) ::)
If you are getting oil coming out of your breather do what we did and fit 2 more breathers on #2 and #3 inlet tappet covers, we've had no problems since.
Sam. ;)
Re: Sparty's bike comes to life... but... (Oil leak still here) 10/6
« Reply #51 on: October 07, 2007, 12:10:37 PM »
All good advise, but I believe from Mikes tone yesterday, it's best to just standby.....!!!
Offline scondon
  • Mmmm......tasty bugs
« Reply #52 on: October 07, 2007, 12:43:22 PM »
    Can we pepper this thread with useless drivel in the meantime, Brent ;) :)
     After reading Mike's last post I got reminded of Andy Kaufman singing the Mighty Mouse theme song on SNL. I checked Wikipedia for any links to that theme and found this at the bottom of the Mighty Mouse listing.
   "In one episode of Biker Mice From Mars, the biker mice burst out of hiding on their motorcycles, singing "Here the Biker Mice come to save the day!", a nod to Mighty Mouse's battle cry."
http://en.wikipedia.org/wiki/Biker_Mice_From_Mars
    OK, ok, maybe not all that funny or even relevant. Just amusing myself 'til Sparty and Mike get it sorted.
« Reply #53 on: October 07, 2007, 01:17:42 PM »
Have at it Sean, just keep holding your breath!  ;)
Offline sparty
  • I just play one on TV
    • Gallery
« Reply #54 on: October 07, 2007, 06:06:33 PM »
Mike was going to come out this weekend from Boston and pull my engine and reseal the bottom end, but now there is no need.  I knew that I could fix this myself.  Thank the Heavens, cause that was to be a ton of work and I am about tired of putting things back together.  Thanks for all the advice guys, this bike is now moving.
1972 CB750 K2 Cafe' Style
Re: Sparty's bike comes to life... but... (Oil leak fixed) 10/8
« Reply #55 on: October 07, 2007, 07:05:36 PM »
How did you fix it Art? ;D
Offline keiths
« Reply #56 on: October 07, 2007, 07:12:52 PM »
Yes, how?
Offline sparty
    • Gallery
« Reply #57 on: October 07, 2007, 07:16:23 PM »
With a big hammer.  I bent the stud over the case. ;D
With an o-ring and high-temp thread sealer, i let it cure for 24 hours and bingo!  It worked for now.
Offline keiths
« Reply #58 on: October 07, 2007, 07:25:38 PM »
Just read your gas post. Hope you didn't jinks it. Good job!
« Reply #59 on: October 08, 2007, 02:10:59 PM »
The leak was coming from one of those APE crank studs, so with the thread sealant and "O" Ring, were you still able to maintain the torque spec on that stud? Did you have to re-torque all those studs in order again? Cheers, Terry. :)
Offline sparty
    • Gallery
« Reply #60 on: October 08, 2007, 05:41:16 PM »
Yep, it torqued right up.  I did check the torque all of the studs.  They are solid.
