Author Topic: question on wiring  (Read 922 times)
jay72chevy1
question on wiring
« on: October 03, 2007, 07:58:28 PM »
Anyone know where I can get a new wiring harness? The main power wire on bike wasnt working because when i went to shut off at the key it stayed on. So I found a hot wire off the plastic slide connector stripped the red hot wire and attatched another wire to it and run it to the posative side terminal. Then the  when i turn key off it shuts off. So somewhere in the harness its messed up going from switch over the main frame.
Offline Rsnip988
Re: question on wiring
« Reply #1 on: October 03, 2007, 09:29:27 PM »
silly question for me to ask but what bike is it for?
R.K.S.
1976 CB750 K6 Full
1976 CB750 K6 Cafe'ish
jay72chevy1
« Reply #2 on: October 04, 2007, 08:30:38 AM »
1973 cb 750  the number says on the motor E But i thought its a K
Offline MrZxp
« Reply #3 on: October 04, 2007, 11:35:02 AM »
You do have a K, the E on the engine serial number is normal.
I would suggest that you download a copy of the shop manual for your bike and (hopefully) therein will be a wiring diagram. Use the wiring diagram to help troubleshoot the electrical problem(s) you are having. A far easier thing to do than try to source a whole wiring harness I would imagine!   :o
Here is a link for the manual download: http://www.sohc4.us/forums/index.php?topic=17788.0
Cheers, Phil
09 Boulevard M90
SOHC4 Member #3336
Offline Rsnip988
« Reply #4 on: October 05, 2007, 11:03:57 PM »
go here:
http://www.sohc4.us/forums/index.php?topic=17262.0
you want the third one, K3-K6 have the same witing diagrams and they are in color easier to follow and trace
if you want a whole new harness
https://www.partsnmore.com/cat_index.php?model=cb750_sohc&category=electrical
Part#24-4001 MAIN WIRE HARNESS LOOM - CB750K (73-75)
 Fits: Honda CB750K (73-75)
Main Wire Harness Loom.
High Quality - NEW PRODUCT!
NOTE: These fits models years listed, early years CB750K use a different OEM part # and they do not supercede to this number so there is a difference.
 at only $75 not too bad a price
hope that helps
RKS
R.K.S.
1976 CB750 K6 Full
