SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Swingarm bushings
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Swingarm bushings (Read 1562 times)
kmenzel
Guest
Swingarm bushings
on:
July 17, 2005, 02:02:06 PM »
Anyone have any suggestions for the felt washers on the swingarm bushing for K4. I dont think i need new bushings but the felt washers are no good. (They go between the cap and the busihings to refresh your memory)
Logged
chippyfive50
Hot Shot
NO PEE ON TEPEE
Re: Swingarm bushings
Reply #1 on:
July 17, 2005, 06:59:51 PM »
I got all of my "odd parts" @ my local honda dealer>>(westernhillshonda.com) quite cheap amazingly enough, my 500 had nylon caps or spacers over the bushings.
Logged
SOHC Member#4000
71' 500K0 #1021237--E1108327
78' 550
72' 750K2(sold to "Craig")
74' 750K4 #2306334--E2303422
73' CL175
http://gallery.sohc4.net/main.php?g2_itemId=14013
coolcat2002
Full Member
Reply #2 on:
May 02, 2007, 06:41:16 PM »
"Instead of the factory felt washer which the oil bled through like a sieve, I use 3/32 cross-section o-rings in the rocker box caps and put a slight chamfer in the inside of the box. Leaks are gone forever. The o-ring material is Viton, because it's oil and fuel compatible and will not swell like some other materials. Another preventive measure is spreading five-minute epoxy on the bolts to eliminate oil weepage through the threads."
This is according to this restorer.
http://www.motorcycle.com/mo/mcgarson/03_Walt_Riddle/
I wonder if you can just make it out of a leather piece.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
Swingarm bushings
