Author Topic: CV Carbs on 81 CB750  (Read 1378 times)
Offline 6adan
« on: October 06, 2007, 07:42:45 AM »
 I am having trouble getting these carbs it idle the way they should. The bike is stock except for the Kerker header and it has the baffle still in. i can set the idle at 1000 rpm but then when it is revved up it will stay at 3000 to 4000 rpm and then slowly come back down and just keep going down till it quits running. Any ideas in this would be great. Thanks Dannie
1970 CB750 JDM,1975 GL1000, 1979 GL1000, 1979 CBX, 1995 GL1500, 2000 GL1500CT Valkyrie, 2008 GL1800 Trike.
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
Re: CV Carbs on 81 CB750
« Reply #1 on: October 06, 2007, 09:05:17 AM »
I just worked on one of these last week.
Same issue.
Turn out the air screws. They are (or should be, if I'm right) underneat the carbs, on the head side (as oppsed to filter side) to 2 or 2.5 turns out, then let the bike warm up (ride at least a mile or 2), and adjust the idle down..
This is a short term solution. If the bike wasn't jetted after installing the kerker, you'll need to increase the idle circuit jet... I havent had one of those apart yet, but the idle circuit may not be removable. If thats the case, you can buy carb drills. drill them out half a size up. i.e. if they are 40's, drill em out to 45 and see what you get. Do not just go nuts. If 45 works pretty good, but still a bit lean, do no go 50, go 47.5 (or whatever).
The same may apply for the main jets. If I get an opportunity to open the carbs on the bike I worked on, I'll let you know what I see.
(Oh yeah, I think it's possible that these bikes run lean stock. It could be that they would all benefit from a rejet. They may be right on the ragged edge of lean stock, meaning, you cant really tell they are lean, but the smallest change dumps em over to '#$%*, this runs like crap' territory too easily.)
No.
