Author Topic: Steering Stem Bearings and Race  (Read 1692 times)
Offline Burke
« on: October 08, 2007, 12:50:10 PM »
I am stripping down my 750 frame to get it ready for blasting, should I remove the races?
If I dont should I put the old bearings in when I re-build it? (It only had 8000 miles on her) Or replace all? Or replace certain things?
I have read on these forums that folks some replace them with tapered bearings. Are these better and easier to replace that to use the OEM style?
If I should remove the race before I get it blasted, how do I remove them?
Any help is appreciated.
Thanks.
Offline ekim98
Re: Steering Stem Bearings and Race
« Reply #1 on: October 08, 2007, 12:59:40 PM »
If your going thru all that work to rebuild I would replace the stock bearings with tapered roller brgs. It's not that much $40 or so and there suppose to help. That's on my list of things to do on mine! If you don't replace them make sure you protect them good before sand blasting or better yet remove them.
Patriot Guard Rider - KY. Ride with Respect
78 750k  cafe bike sort of
67 305  Superhawk (working project)
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #2 on: October 08, 2007, 01:02:48 PM »
you're wasting your time if you don't install tapered bearings.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline Gordon
  • 750K1, 550K2
« Reply #3 on: October 08, 2007, 02:24:40 PM »
Agreed!  If you already have it stripped down, you'll be doing yourself a big favor in the future by replacing them with tapered roller bearings, and it will most likely be the last time they'll need to be replaced.
Offline Burke
« Reply #4 on: October 08, 2007, 05:49:49 PM »
Replacemnet it is.
So what is the trick to remove them races?
Offline jtb
  • An unlikely
« Reply #5 on: October 08, 2007, 05:56:09 PM »
Beat them out with a long drift and big hammer. ;D ;D
1977 CB750F
1985 V65 Sabre
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #6 on: October 08, 2007, 07:05:02 PM »
Keep them, you can use then to tap in the new ones ;D
Offline Gordon
  • 750K1, 550K2
« Reply #7 on: October 08, 2007, 09:44:28 PM »
On one particularly stubborn lower bearing race, I cut through it about 3/4 of the way with a Dremmel cutting wheel, and then broke it off with a flat-head screwdriver.  The sound of it cracking was extremely satisfying, especially after several hours of wrestling with the thing unsuccessfully.
Offline xtalon
« Reply #8 on: October 09, 2007, 06:06:26 AM »
If you use All Balls tapered bearing kit, be sure to keep your old bearings/races because you will need to measure the stacked height to determine which washer to use for installation of the new bearings.  I don't know if all tapered bearing kits are the same in terms of this or not.
--xTalon
1976 Honda CB750K
2006 Yamaha R6v
Offline Steve F
« Reply #9 on: October 09, 2007, 06:31:58 AM »
Guys, when you purchased your tapered bearing sets, did any of you get a dust shield of any kind?  If I recall, I ended up making a rubber disc to cover the exposed side of the lower bearing, and it was a pain to figure out.  >:(
Offline paulages
  • 1976 cb735
« Reply #10 on: October 09, 2007, 11:06:34 AM »
i destroyed mine removing the stock lower/inner race the first time i did the conversion, and bought a new one from honda. the seal doesn't come with the bearings.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
