Author Topic: What head torque should I use for a 750 big bore?  (Read 1307 times)
Offline Patrick
« on: October 09, 2007, 08:22:44 PM »
My top end on the K0 750 project is going to be installed probably Thursday. The pistons are 64mm. The studs are aftermarket, brand unknown. Should I stick to the stock torque on the stud nuts or go tighter. Will the bike be prone to oil leaks if I don't increase the torque?
And while I'm at it, among the parts that came with the bike is a NOS camshaft holder. Only one. It seems a shame not to use it. Will it have ill effects on the cam shaft if one holder is new and the other original? The original holders look fine. I haven't spec'ed them.
Thanks,
Patrick
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Re: What head torque should I use for a 750 big bore?
« Reply #1 on: October 10, 2007, 04:39:53 AM »
 I'd 20lbs is safe with with some engine oil as lube
Offline KB02
« Reply #2 on: October 10, 2007, 05:13:12 AM »
I stick with the stock cam holders, too. No sense in mis-matching anything, you know?
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline Patrick
« Reply #3 on: October 10, 2007, 12:46:45 PM »
Thanks, guys. I'll do twenty pounds and, as much as I hate not using this brand new cam holder, I also don't want to spring $120 for another new one. I can find several better ways to spend $120 on this project....
Patrick
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline Big Jay
    • CBRzone
« Reply #4 on: October 11, 2007, 11:33:36 PM »
Are the studs straight, or undercut in the middle like oem. What color are they?
Jay
