SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
CB550, goldwing frontend, modern brakes
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: CB550, goldwing frontend, modern brakes (Read 2061 times)
Baas_C
Guest
on:
July 18, 2005, 10:05:39 AM »
To put a golfwing front end o my CB550 all i would need ot do it press out the goldwing's triple clamp stem and press in the CB550 stem, right? What modern rotors will fit on the goldwing hub? which calipers can be most easily adapted to fit the goldwings forks?
Thanks
Chris
Logged
kghost
Really Old Timer ...
www.facebook.com/RetroMecanicaAustralia
Re: CB550, goldwing frontend, modern brakes
Reply #1 on:
July 18, 2005, 02:52:32 PM »
Later goldwings like the 77-78 had dual disks. But had comstar wheels instead of spoked.
Logged
Stranger in a strange land
Baas_C
Guest
Reply #2 on:
July 18, 2005, 05:26:43 PM »
Oh, must have got my info mixed up...So are there any disks that will bolt onto the CB550 hub? a caliper that will bolt up to the fork? or will these things need modification?
Logged
kghost
Reply #3 on:
July 18, 2005, 06:50:42 PM »
Several members have had good success with using the other fork leg mounting points on thier 750. I don't know why it wouldn't work on a 550. Check the FAQ.
Logged
bryanj
CB500 Number 1000036
Reply #4 on:
July 19, 2005, 02:38:35 AM »
As nicely and i will send you a how to on twin discs.
Logged
Baas_C
Guest
Reply #5 on:
July 19, 2005, 11:29:44 AM »
I found the FAQ on how to do the dual discs and caliper reversal, thanks for the heads up. Im still looking to see if I would be able to put modern discs and calipers on, I want at least two piston calipers.
Thanks
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
