Author Topic: gas is coming out of my airbox....  (Read 882 times)
Offline eosmontana
  • 71k2, 78f2
    • SubM2
« on: October 11, 2007, 02:18:38 PM »
I have been riding my 78' 750 f2 all summer... it sat for a week and a half while it was rainging.... sunny day came and i went for a ride.... as i pulled into the store parking and stopped gas started pouring out of the left side seem on the stock airbox.... rode home and watched it.. no gas while riding but as soon as i stopped again it started pouring out.... where would it be coming from?
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
Re: gas is coming out of my airbox....
« Reply #1 on: October 11, 2007, 02:23:54 PM »
Plugged overflow + stuck floats.
No.
Offline Patrick
« Reply #2 on: October 11, 2007, 02:27:38 PM »
Your carbs. It sounds like your floats aren't closing one or more of your needle valves all the way. Could be some crud from the tank, could be worn needles, could be a bad float. It happens periodically with my 750 if I don't shut off the petcock when I park the bike. Always turn off the petcock when you park the bike. Always. To stop the flow without pulling and cleaning the carbs, like you probably should, try tapping on your carbs to try to vibrate the needle back into the seat when it starts to leak.
Patrick
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline eosmontana
  • 71k2, 78f2
    • SubM2
« Reply #3 on: December 15, 2009, 02:08:25 PM »
I actually figured it out... and i feel like an idiot... My gas cap wasn't completley on and when i turned gas was coming out of the cap and going into the overflow drain under the gas cap door.. which coincidently drained on top of my airbox giving the illusion of gas coming out of the airbox.... thanks for the replies.... i guess i am as stupid as I look.
Offline tlbranth
« Reply #4 on: December 15, 2009, 04:10:01 PM »
Yo eos, you found it dincha?
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline eurban
« Reply #5 on: December 15, 2009, 06:15:47 PM »
Probably wise to run the hose from the overflow drain all the way down to swingarm pivot area so that gas ends up on the street rather than on top of the motor or exhaust.  Run the tubing from the carb overflow / bowl drain nubs (you do have tubing going to each bowl don't ya?) to the same spot.
« Last Edit: December 15, 2009, 06:18:47 PM by eurban »
Offline celebutante
    • my website, yay
« Reply #6 on: December 16, 2009, 01:27:01 AM »
Yeah, and always remember to close the petcock, especially if your floats stick. Otherwise, you might just be a total moron and START A FIRE in your airbox. Luckily, I never did that. Oh wait... I DID do that  :o
