Author Topic: This doesn't look right-Bent motor mount  (Read 2121 times)
Leurw
« on: October 11, 2007, 04:01:15 PM »
This isn't suppose to look like this is it?  It's one of the really long bolts (threaded at both ends) for mounting the engine. I put it next to a straight rod to emphasize the "bent-ness." Do I need a new one?  If so, where can I get one?
Thanks guys, appriciate the help!
-Robb
Re: This doesn't look right-Bent motor mount
« Reply #1 on: October 11, 2007, 04:27:49 PM »
yes you need a new one , never seen that happen before(and on both ends no less)
the bad news: good f'ing luck finding one , i would keep my eye on parts lots on ebay
the good news: it's not that costly, if you go the parts lot route
good luck mt friend
Offline scondon
  • Mmmm......tasty bugs
« Reply #2 on: October 11, 2007, 04:50:48 PM »
 Usually those get bent when the footpegs have a violent collision with the ground, or garage doorway(in my friends case). Don't know what kind of bike you have but you might want to check the "parts for sale" section of this site or post a listing in the "parts wanted". As spikeybike points out, there is always ebay.
Offline mkramer1121
« Reply #3 on: October 11, 2007, 05:09:39 PM »
Or they get bent upon removal from the frame....I did it as well...
Offline Jinxracing
  • It's hot shit, not
  • '70 CB750 K1
    • The Hairy Nickel
« Reply #4 on: October 11, 2007, 05:21:45 PM »
I had been searching for a set of those 3 long motor mount bolts for a looooong time and had no luck here on the forum or on eBay. They're listed on the Honda microfiche at about $25 each, but now that I'm mounting rearsets I'm going to be making my own shorter version of the footpeg bolt.
Good luck, and be sure to post a source here if you find one!
–Captain Horatio Hornblower
www.thehairynickel.com
Offline Steve F
« Reply #5 on: October 11, 2007, 05:40:18 PM »
It can be straightened.  Don't bother with trying to locate another bolt.  Find a local machine shop with press, and any machinist worth a hoot can do it. (without screwing it up).
Offline sparty
  • I just play one on TV
    • Gallery
« Reply #6 on: October 11, 2007, 05:41:48 PM »
Oh crap..sounds like I'm slightly out of luck  :(
I guess I'll watch the forus and ebay, thanks 4 all the help!
I'll be sure to post if I find anything
-Robb
I had a guy at a local machine shop make me one out of stainless steel.
1972 CB750 K2 Cafe' Style
Offline eurban
« Reply #7 on: October 11, 2007, 05:43:00 PM »
You can get threaded rod of the correct size and pitch, cut it to length and use nuts on both ends.  This seems to be the only option (Sparty's custom made bolt would be another) when a person gets the idea that they want to replace all the fasteners on their bike with stainless ones.  Stainless would be as good idea as once you cut it to length, you can smooth and polish the cut end so that it both looks nice and won't rust.
« Last Edit: October 11, 2007, 05:44:48 PM by eurban »
Offline Short Round
« Reply #8 on: October 11, 2007, 05:44:10 PM »
When I removed my 550 motor this past weekend I found that the top bolt in the rear of the motor was bent, played hell getting it out but I found this guy to have the most parts for our bikes or atleast my 550.  Try the link and enter you bike info, then go to the frame diagram.  http://www.westernhillshondayamaha.com/fiche_select.asp.....................................Chris
1974 CB550
Offline rhinoracer
« Reply #9 on: October 11, 2007, 06:10:09 PM »
I thought they were supposed to be bent after looking at mine and some others.
I think I'll straighten mine with a 5# hammer or make one from cold rolled or stainless 1/2" stock. Does 1/2" work or does it need to be turned down to 12mm?
Baja native.
Offline rhinoracer
« Reply #10 on: October 11, 2007, 07:15:49 PM »
By the way I wouldn't  use all thread rod, it's too soft for the job, plus the threads would dig into the aluminum cases.
Baja native.
« Reply #11 on: October 11, 2007, 09:04:42 PM »
They would be metric with maybe a rolled thead. If they are that hard to find,  I could probably make some up... I would start with 12mm (not sure of Dia) ground stock or drill rod..
 AllThread or Reddi-Rod might be of low grade and would be undersize where it counts, ie keeping motor where it should be..
 Easy way to staighten..tap the thead size into a pc of 3/4 bar..then thread on as far as it will go..chuck in lathe and soft hammer till relatively staight to the eye.. should be fine..
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #12 on: October 12, 2007, 12:18:30 AM »
Put a nut on it, lay it on an anvil and bash it straight again.
done.
RSV12K
« Reply #13 on: October 12, 2007, 06:14:22 AM »
I probably have a couple of those as well as other engine bolt/rods. If you're interested, get in touch. Haven't got a clue what a fair price would be because I don't even know what they normally go for, however. mjalex007 at yahoo.com.
Offline eurban
« Reply #14 on: October 12, 2007, 06:21:54 AM »
Stainless threaded rod can be be had in metric and standard sizes.  It won't be quite as strong as the stock bolts but it should do the job.  The european supplier where I got all the stainless hardware for my 750 project recommended the rod but I didn't want spend the $ at the time.  The rod would be just slightly undersized but I doubt that would be much of an issue once things are torqued.  The stock bolts don't fit snugly in the crankcase anyways. As to it messing up the alloy cases . . .the stock bolts are typically driven through with a hammer undoubtedly scuffing things up on the way . . .All this said, I would certainly straighten out the stock pieces, yours don't look to be beyond salvage.  If looks matter, having the stock pieces cleaned up and plated would be an option.
Offline gtyler5
« Reply #15 on: October 12, 2007, 06:52:30 AM »
I have a set of the 3 long bolts for a 750 I would be willing to sell if someone needs them PM or email me.
1976 CB750F cafe
1978 CB750F (in progress)
1993 CB750 Nighthawk
Offline cleveland
« Reply #16 on: October 12, 2007, 04:05:26 PM »
I just sent a whole set of engine bolts to a SOHC4 member.  Anyone that picks up parts bikes is bound to have a few laying around.  In fact, you have already gotten a couple of offers.    ;)  That's what I love about this forum, you can find almost any part you need and they are practically given away.
Offline nteek754
  • 1973 K3/750/836/70 1970 750 chopper 1973 cafe
« Reply #17 on: October 12, 2007, 05:00:04 PM »
Hey all, Ive got a few out in my shed for the 750 but damn dont let that stop you from riding  threaded rod will work JUST fine trust me.  But from the sounds you can make your own or STAIGHTEN THAT ONE good luck have fun Craig in Maine.
seven fifty four ever its not the destination its the journey Ive been collecting these old dinasours for 33 years . they are quite an ICON
