Author Topic: CB550 Cafe Interceptor - Gentleman's Roadster  (Read 345704 times)
Re: CB550 Cafe Interceptor - Gentleman's Roadster
« Reply #600 on: October 22, 2015, 09:02:50 PM »
Very nice work Frank! Jimmy will have to lift a cold one to you every time he uses it.
Jimmy, be glad you aren't buying him a cold one every time you use it like a music licensing bit...
David
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #601 on: October 22, 2015, 09:05:26 PM »
David
Got that right David. I'd much rather tip a cold one to (me) every time I use it.
Gotta go, time to check the valves.  ;D
« Last Edit: October 22, 2015, 09:15:03 PM by FunJimmy »
« Reply #602 on: October 23, 2015, 04:20:11 PM »
Better not have the Canadian strength brews if you are counting each tappet cover as a use.
.that would make for no memory of the event after having one for each on and off as a use...16 x 12-16 ounces would be between 192-256 ounces of beverage. Might have to empty the bladder a few times and have an incredible headache the next day.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #603 on: October 23, 2015, 11:58:19 PM »
I've always liked my NOS Kerker header on this bike, but chrome plated steel is susceptible to bluing, it's heavy and eventually rusts so stainless steel is a great way to go. Until the recent introduction of Hindle Exhaust Systems there have only been a couple of infrequent producers of stainless exhausts for CB550's and 750's. Hindle Exhaust Systems is a worldwide leader in aftermarket exhaust systems and now offers performance exhausts for CB550's, 650's, and 750's.
I got home from an out of town business trip to find that my package from Ripple Rock Racers had arrived! Say hello to my NEW stainless steel Hindle 4-2-1 exhaust system. It's sure amazing to see and feel the flawless build quality a true dedicated performance exhaust manufacturer delivers.
Gonna look purdy all polished and shiny.  ;D
« Last Edit: January 02, 2019, 06:06:43 PM by FunJimmy »
« Reply #604 on: October 24, 2015, 12:45:38 AM »
Looks pretty awesome. Fitment looks superb.
Offline calj737
  • I refuse...
« Reply #605 on: October 24, 2015, 03:02:41 AM »
It sure does look nice. But you should realize that stainless with also discolor with heat cycles Jimmy. Plated steel is not the only metal to succumb to heat.
Stainless is a great metal choice for motorcycle exhaust because of its corrosion resistance, but it is more brittle and will suffer from the heat cycles more than a mild steel. Ultimately, it will crack sooner than mild steel, but mild steel will corrode much sooner than stainless. I understand the Hindle system uses a much thinner walled tubing than others, so its durability will be interesting to note. Not suggesting for a moment thats its not a First Class product, just making an observation.
I'm fortunate that all my 5xxs use a perfectly fitting, top class stainless 4:1 from another so my need to explore the Hindle isn't there. But for 650 guys, it looks to be the cats pajamas.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #606 on: October 24, 2015, 07:55:46 AM »
I've had and still own motorcycles with full stainless systems so I know about the expected discolouration. Stainless doesn't get the harsh bluing you see on chrome but goes a soft gold colour. It looks really nice and the pipes are super easy to clean if the tubes are polished first.
I'm not sure I'd worry about durability though. Hindle has been in the performance aftermarket exhaust business for a very long time. They manufacture systems for street and off-road bikes that see extreme conditions and stresses. The tubing might be thinner wall than others but the entire system fits stress free and spring loaded. I also like that it supplies with a model specific muffler hanger.
Something else worth mentioning. The pipe routing provides considerably more ground clearance than my Kerker or the Yosh replica pipes while providing unobstructed access to the oil filter and drain plug!
« Last Edit: October 24, 2015, 07:58:23 AM by FunJimmy »
Offline tweakin
  • tear down
« Reply #607 on: October 24, 2015, 08:29:51 AM »
Looks great Jim.  nothing better than stainless, IMO.
« Reply #608 on: October 24, 2015, 10:03:50 AM »
Looks good Jim. It's a full spring mount? As you said if it fits really well and is spring mounted, then thin is good. I'd like to ask Lang why the larger primary OD for the 550 though.
Offline flatlander
« Reply #609 on: October 24, 2015, 02:05:32 PM »
those pipes do look good. if i get fed up with my stock ones i need to put them on the x-mas list.
« Reply #610 on: October 24, 2015, 03:53:17 PM »
Flatlander: If you get "fed up" with your stock pipes, I'll take them!
Offline scunny
  • don't call me expert
« Reply #611 on: October 24, 2015, 04:47:34 PM »
They do look big.
Nice looking setup
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #612 on: October 24, 2015, 06:24:05 PM »
Yup. Full slip fit with springs. Spigots at the head.
So that it works well with Mrieck stage III heads!  ;D
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #613 on: October 24, 2015, 06:27:00 PM »
Couple more pics before I pull it and get polishing.
« Last Edit: January 02, 2019, 06:06:25 PM by FunJimmy »
« Reply #614 on: October 24, 2015, 06:51:26 PM »
Jim,
You may need some more red powdercoated bits (the exhaust springs or the nuts for the exhaust studs)!  ;)
That Hindle pipe looks damn good.  I'm very happy with the construction on the one for my 650, too!
« Reply #615 on: October 24, 2015, 06:56:40 PM »
Cost probably Brent. I have a 4/2/1 for a 900RR custom made for 2 Brothers when Freddie Spencer raced for them (think I mentioned it somewhere else on this forum). the primary tubes start at about .75....it is an awesome pipe with 3 sections before the final primary size. I was told it was built by some fella that makes NASCAR headers. The first bike it was bolted to felt like a supercharger was installed. A great exhaust can make a huge difference
« Reply #616 on: October 25, 2015, 12:07:38 AM »
Jim,
Not red, he needs more blue bits...
He's got the red valve/tappet covers and a few other tidbits red... The deletion of those blue calipers just leaves the bike out of balance with the fung shui.   ;D ;) :D
Offline flatlander
« Reply #617 on: October 25, 2015, 12:09:12 AM »
ha, not so fast! i'm quite attached to them. only now with the better flowing head i do keep running into a wall that the stock pipes create. i do like them but they're certainly not a performance piece.
« Reply #618 on: October 27, 2015, 09:36:08 PM »
Jimmy, what's keeping you...doesn't your boss know you are dying to polish up that exhaust and get it tuned so you can take a nice long ride to enjoy the melody of your new Hindle system?
So, you had a teaser picture of a different 550 motor...was that yours or just teasing on the exhaust?
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #619 on: October 29, 2015, 12:32:22 AM »
The previous (Cone) muffler bracket won't fit the Hindle exhaust so back to the lab I go.  ;D
« Last Edit: January 02, 2019, 06:39:27 PM by FunJimmy »
« Reply #620 on: October 29, 2015, 01:11:53 AM »
Very cool Jimmy!  Just busting your balls earlier....it isn't like you are slacking watching American baseball World series while buffing and polishing your pipes.
I am certifiable as I enjoy sanding and polishing.
Thank you for the eye candy, it is a nice birthday present.
« Last Edit: October 29, 2015, 01:14:39 AM by RAF122S »
« Reply #621 on: October 29, 2015, 07:05:39 AM »
Nice bling. Videos never do pipes justice but you'll have to post one anyway when you get the new can from Kemp!
Offline GV1390
  • Express Gratitude.
« Reply #622 on: October 29, 2015, 08:57:49 AM »
Kemp surely is THE man.  :P
Nice system!
93' GSX-R1100, 78' CB550, 71' CL350, 71’ CB500 & 02' ZRX1200R.
Offline brandEn
« Reply #623 on: October 29, 2015, 05:03:45 PM »
Looks good Jim, are you polishing that while its installed?
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #624 on: October 29, 2015, 06:06:56 PM »
No. It's super quick & easy to remove. With the springs removed the exhaust spigots remain fixed to the head and the three piece header slips right off. I can't imagine how I'd polish a single piece header other than by hand and I don't have a lifetime to do that.
