Author Topic: CB550 front sprocket play  (Read 2021 times)
rlarkin70
« on: October 14, 2007, 10:53:57 PM »
hi Everyone-
I ran into a possible issue when I was putting back together my 76 CB550. The 17T drive sprocket seems to have some side to side play. I didn't notice it when I took the sprocket off. There is about 0.5-1.0mm of side "play" on the sprocket. This is with the sprocket plate on, and the plate bolts tightened.
If that's not clear, what I mean is that (looking at the photo) if I grab the sprocket and pull it towards me, it will slide back and forth (side to side in relation to the bike) on the shaft.
Is this normal? What should I do, if anything? I couldn't find an mention of what the normal value for this clearance is in the Clymer or Honda sevice manuals.
-Ron
Re: CB550 front sprocket play
« Reply #1 on: October 14, 2007, 10:55:45 PM »
normal
Offline Deltarider
« Reply #2 on: October 15, 2007, 01:55:00 AM »
It's normal.
CB500K2-ED Excel black
rlarkin70
« Reply #3 on: October 15, 2007, 07:06:10 AM »
Thanks guys, that's good news. I think maybe with all the crud in there I didn't notice it when I took it off. I get a bit paranoid with any parts that are involved in spinning a heavy chain right underneath my a$$!
-Ron
« Reply #4 on: October 15, 2007, 08:31:35 AM »
Your sprocket teeth are worn out.
Loose on shaft is okay.
rlarkin70
« Reply #5 on: October 15, 2007, 08:37:16 AM »
yeah, they are. I am using the existing sprockets (drive, and rear) and chain while I get the bike back together, and tune it up. I am going to replace both sprockets at the same time, and get a new chain.
« Reply #6 on: October 15, 2007, 08:43:42 AM »
8)
