Author Topic: Anyone ever use alumiprep?  (Read 8623 times)
Offline ksmith0034
  • When I grow up I want to be a
    • Please subscribe to my motovlog
« on: October 15, 2007, 01:33:30 PM »
Anyone ever use alumiprep?  I just ordered a qt bottle from aircraftspruce.com ($16.95)
I will let you know how it works.   ;D
It took 10 years but she's finally done!
Stocker 2 Rocker CAFE conversion
My YouTube channel HERE:
https://www.youtube.com/MotoCafeRacer
Offline 736cc
Re: Anyone ever use alumiprep?
« Reply #1 on: October 15, 2007, 02:53:43 PM »
Prepping aluminum  for what?
« Reply #2 on: October 15, 2007, 04:50:33 PM »
Yes, I've used it.
It etches the oxide off just prior to paint... So, you don't have to use a special aluminum paint to etch the oxide while painting.
Alumiprep for aluminum, Metalprep for ferrous surfaces.
cheers,
Offline ksmith0034
« Reply #3 on: October 15, 2007, 05:24:47 PM »
Just to clarify, I am trying to clean all the aluminum goodies that are on this bike.  There are tons of nooks and crannies that I can't get into to get them clean.  I am not looking to piant the aluminum, just clean it and polish it up a bit.
Thanks gang.
« Reply #4 on: October 15, 2007, 05:50:09 PM »
From the TDS:
Alumiprep 33 is a phosphoric based acidic cleaner used for cleaning, brightening and etching aluminium surfaces.  Alumiprep 33 should not be used on alloys or casting containing copper.  Alumiprep 33 cleans and conditions the surface leaving it corrosion free, ready for welding, painting or chemical coating.
Now just me...
You should be aware that little, if any, of the aluminum on your bike is pure aluminum.  It is mostly alloy, meaning it was blended with other metals.  Although, I don't know that these alloys contain copper, you might try an obscured area to apply as a test.  Also, I doubt that the alloys used on the bike are uniform composition, meaning different parts can be of different alloy ingredients.  You may wish to consider testing each piece.
cheers,
Offline hopterfixer
    • My flickr Gallery->
« Reply #5 on: October 15, 2007, 05:54:36 PM »
One would usually use alumiprep prior to applying alodine.
Offline aptech77
« Reply #6 on: October 16, 2007, 08:12:50 PM »
I use it at work all the time. I also used it on my engine before I painted. Great stuff. Did you get the alodine also? You should have.
Offline 750essess
  • Orleans Cycle Repair & Resto
« Reply #7 on: October 17, 2007, 05:46:12 AM »
I used alumiprep and alodine also. It makes sort of a grainy pattern on the aluminum alloy covers, kind of like a damascus knife. I thought it looked so cool i didnt paint it and is holding up very well so far. Alot better than polishing the sucker all the time. The alodine does not work on the sprocket cover, it must be zinc or something.
Orleans Cycle Repair and Restoration
76CB750F
69Z50
XR650L
Offline ksmith0034
« Reply #8 on: October 17, 2007, 05:59:55 AM »
what does the alodine do?
Offline 750essess
« Reply #9 on: October 17, 2007, 06:20:21 AM »
Its a chemical conversion that keeps the aluminum from corroding.
76CB750F
69Z50
XR650L
Offline Short Round
« Reply #10 on: October 17, 2007, 06:31:41 AM »
would you guys that have used this, would you say this is the best way to go for paint prep?
1974 CB550
Offline stearmandriver
« Reply #11 on: October 17, 2007, 09:56:56 AM »
Just to make sure you understand.  Alumiprep is an acid etching solution!  It is only used on bare aluminum prior to alodine and paint.  You can stop after alodine if you like the look of alodined parts.  Its best if you prime and paint over the alodine for longest lasting protection.  Alumiprep is NOT a cleaning and brightening product, ie. "I'm looking forward to that big ride on Saturday,  I think I will Alumiprep the engine covers so they shine for the ride."
I'm not trying to be a wiseacre,  I just don't want anyone making a mistake that might damage their machine.  I restore aircraft as another hobby and use the stuff all the time.  It is for bare, pure aluminum sheeting and parts.  Used prior to the application of alodine and further coatings.
Good luck!
Dave
"Everyone needs to be passionate about something, anything...  I'll help you collect acorns if thats your thing, just don't sit there and tell me your bored!"
Offline aptech77
« Reply #12 on: October 17, 2007, 08:31:40 PM »
  :D ;)
Offline ksmith0034
« Reply #13 on: October 23, 2007, 07:45:19 PM »
Here is the result of one very short test on my rear hub:  it is now clean.
I did not notice anything drastic.  Nothing shiny, nothing turned black.  Just a bit cleaner.
Now I know.
